Has anyone read this?
Has anyone tried it?
Does it work?
A few people have looked at the thread, but nobody has anything to say in the concept, I was sort of interested.  If I finally went to an RB25/30 and did this would I get the gains the OP is stating?
https://www.sau.com.au/forums/topic/470314-poly-quad-heads/#findComment-7828434
I've read it. Looks good in theory and has apparently had good results if the article is to be believed. I am a little surprised that it hasn't been done before but it looks to have the potential to increase efficiency and hence power and/or economy. Hopefully we will see more in the future.
https://www.sau.com.au/forums/topic/470314-poly-quad-heads/#findComment-7828953
I read it too and even if it does produce the gains, the cost makes it prohibitive to most (6-700us per cylinder + valves). You'd be better off investing in an EFR turbo for your 25/30, should provide plenty of bottom end poke without polyquad and you'd have change.
https://www.sau.com.au/forums/topic/470314-poly-quad-heads/#findComment-7828956
Yes I don't think its a viable mod for most people. I think the point of the article was that for an OEM  manufacturer the cost would be very small as the design would be built in to the manufacturing process.
https://www.sau.com.au/forums/topic/470314-poly-quad-heads/#findComment-7828994
Yes, I agree Bob but op did specifically ask about if it would be beneficial on a 25/30 build. I think Oem's would be unlikely to take this up as it's patented and they're not in the business of paying royalties. I am surprised they haven't come up with there own version though.
https://www.sau.com.au/forums/topic/470314-poly-quad-heads/#findComment-7828998
Thanks guys, I agree to a point.  And the theory and the author/inventor?? certainly points to the idea being a good one....and we can do it and not have to pay royalties etc because we are not a business.  But before making any life changing decisions I would like to see an independent appraisal.
I am surprised that more track cars don't use it though....this puts doubt on the concept.
https://www.sau.com.au/forums/topic/470314-poly-quad-heads/#findComment-7829027
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
