I am attempting to find one of these wheels. 40300-R4671 is the Nissan part number. I understand that they were used on the mid 70s C110 Skylines. They were also used on the USA Datsun 810 with a different part number (40300-U8925). I only need one wheel without the center cap or lug nuts. Any information on these please feel free to email or pm me. Thanks.
https://www.sau.com.au/forums/topic/47037-c110-alloy-wheel/
yeah, but i really don't think that you need to buy one from australia....surely they are available in USA? $50 aus dollars and you sort out the freight arrangements, cos i work stupid hours and cant organise things at all....(damn work)
https://www.sau.com.au/forums/topic/47037-c110-alloy-wheel/#findComment-954051
Check your private messages.
https://www.sau.com.au/forums/topic/47037-c110-alloy-wheel/#findComment-954274
Thanks Jason (V8skylineMAN) for helping me out. I'll be awaiting the arrival of this wheel. I only wish international mail was faster! :cheers:
https://www.sau.com.au/forums/topic/47037-c110-alloy-wheel/#findComment-964401
Well, the wheel arrived today! It only took eight days to ship from Coomera Shores, Australia to Fontana, California, USA! I have had interstate packages take longer! Thanks again, V8skylineMan for your quick response and cooperation in helping me complete this set of wheels that was seemingly impossible to do in the US. I'll post some pictures in my gallery as soon as I get the wheels cleaned up and mounted. (If you guys don't mind seeing this old US Skyline cousin). :D
https://www.sau.com.au/forums/topic/47037-c110-alloy-wheel/#findComment-975211
Thanks, here it's called a 'Datsun 810'
I knew it was an 810, but I didn't realise that you called them that.....
Our P510 is a jap bluebird, but we call them 1600 cos the size of the motor.
610 is 180B what the "b" is i dont know
I believe you call them 'estate' over there.
No, we call them station wagons......Japanese called them Estates...and possibly UK do also but I'm not sure.
https://www.sau.com.au/forums/topic/47037-c110-alloy-wheel/#findComment-979458
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
