44 minutes ago, niZmO_Man said:
PS4 is out apparently.
Yes there is only one size in 19's unfortunately which is the rear tyre size only so no staggered width (to match the stock setup and rims). The PS4S appear to have more sizes but isn't out yet.
I'm contemplating waiting it out for the PS4S but will check the compound as I have driven R compound before (I think they were 140 treadwear or so) and found daily driving required wheel spin in the 200sx to get traction on a commute in winter.
8 hours ago, R377 said:
Go ps2 or 3, RS3 or AD08. Maybe look at nitto
PS2 don't have suitable sizes in 19's for the V36 with stock 19 staggered rims from what I saw. Edit: OK, so the sites I was looking at had the 245/40/19 out of stock but appears 245/40/19 at front and 265/35/19 at the rear might be a possibility.... Although with the PS4 out I didn't look so hard at the PS2.. But this is a possibility now.
The PS3 is less of a performance tyre than the PS2 and PS4 (it's not an upgraded PS2 design necessarily) from what I read so excluded that. But I could be wrong.
The RS3 unfortunately only comes in the the 245/40/19 and 275/35/19 combo which is pushing the limits for the car and rims I believe.
And the AD08 appears hard to find in the right sizes (or even 20mm wider front and back), but can find the R compound AD08R in suitable sizes (both front and back 20mm wider than stock and 1% smaller all round) but feel an R compound for 99% daily drive might not be the best choice coming into winter.
Edited by Pete_Repeat
i would go 20mm max on the orig tyres so 245 front and 265 rear.  Your prob only track it once or twice so an ad08 or rs3 although great for the track will wear out much fast than a regular tyre.
We have continental mc5 on our v36 skyline 18".  They don't do do 19".  They are super comfy, low NVH and will get good km out of them.  We will do a track day and hillclimb here and there, for fun.  For a road tyre they grip well but would prob be 2 secs a lap slower than a semi on the track - who cares we aren't going for any records and for 99.9% of our driving they do us well on the road.
Your pretty obsessed with the ps4, can you get them from overseas ?
1 hour ago, admS15 said:
AD08R is not an R compund. It's equivalent to a Hankook RS3.  A050/Z221  are R compound.
Edit Ad08 is the predecessor to ad08r, that why it would be hard to find and would be old stock
Makes sense.
Anyone used or advise the AD08R for daily use then? Just their marketing really focus' on the track. I don't mind firm ride or anything, and would prefer a good turnin an less tyre roll but more concerned about getting heat into them.
Maybe I need to google a little more on them then.
I'd go 245/40 front and 265/35 rear
http://www.stgeorgetyres.com.au/tyres/yokohama-neova-ad08-265-35r19-semi-slick-tyres-2653519-265-35-19/product-detail.aspx
That's probably old stock, best to ask for production date
AD08 (not R), mate's old MY05 WRX STi, quite comfortable for daily use, more wet grip than the standard RE070. No track work unfortunately (he sold the car soon after). Extreme overkill for daily use but if you're tracking it, then might as well get them (or Potenza RE-71R). If you're doing a lot of driving then I'd go something like INVO or similar road tyre.
  • 1 month later...
OK. I am now determined to get the new Pilot Sport 4S. Stress on the S.
So it looks like the stock fronts 225/45/19 are ehre, but the rear 245/40/19 has no defined date (if any). Only available in the US at the moment.
So I am looking at the following with pro's and cons to each;
- Stock sizes
        - Too long a wait, if the 245/40/19 even get here seeing that is the only 19 inch size in the PS 4 so they may never bring it in who knows.
- 225/40/19 and 245/35/19
        - Cheapest combo by about $200 for the set of 4.
        -  Available now
        -  3.4% and 3.75% smaller rolling diameter so speedo out by almost 10% with 7% OEM error. This isn't a big problem for me really, other than when I finally track it that te 180 kmph limited will occur easier.
        - VDC and ABS should be fine I believe as almost the same reduction front and rear.
- 235/40/19 and 255/36/19
        - $200 more epxensive
        - Available mid August, although I can wait if need be
        -  2.2% and 2.6% smaller so a little less speedo error.
        -  VDC and ABS almost the same conditions as above.
Anyone have any comments?
Just now, The Max said:
Your determination to go with the PS4S is well-founded. I got them for the fronts because of the OEM size and they're worth every cent. They certainly outgrip my PS3 tyres in the rear.
I think I read too much as every tyre listed in this thread either didn't come in the right sizes or I eventually found feedback to say otherwise. These are the only tyre I have only  heard good feedback on. Yeh I know they are fairly new, but they have been out for 6 months in the states.
I've gone round and round in circles really. From cheap to expensive. Tempted with some cheap option to find they were excessively noisy. Now sitting at the upper limit although the 225/40/19 and 245/35/19 (lower profile only) seem to be a "reasonable"  $1476 at the moment. I can live with the extra 3% speedo error (easier to calculate at 10% including oem error) knowing the ratio front to rear diameter/circumference is almost the same.
I'm almost there. Will likely order them unless someone throws a spanner in the works in the next day or two (more to do with sizing) . Sorta need the rears changed with this cooler weather as they spin easily in first gear in a straight line with the clutch already out.
Took the plunge.
Pilot sport 4s with 225/40/19 and 245/35/19.
Price, availability and very similar diameter change sold me. 10 percent speed error here we come (only up a little from oem 7 percent) and 162km/h real speed limiter ha ha.
Getting installed on Saturday.
Now deciding on wheel alignment settings. Might resurrect my other topic on this again.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
