1 hour ago, Lithium said:
Interesting, same as the 9.25mm lift 264s - so to confirm, they are definitely 260 advertised duration?
Yup, there was talk about going a 222/222 and that was actually going to push the advertised duration to 226 but drop the lift down to 10mm
From Kelford
Quote
I personally would run the 226° ones, given their slightly shorter adv. duration (it’s a design and acceleration thing that makes this the case)
Edited by SimonR32
  • 1 year later...
I’m in the same boat as well cannot decide between Tomei or Kelford. Will be using
Borg Warner EFR 8374 1.05a/r and NITTO's 2.8Ltr Stroker Kit. Car will be mostly street so looking for response.
Looking at these:
Tomei Procam 260Degree 10.8mm Lift
Tomei Procam 270Degree 10.8mm Lift
Kelford 182-S 274/270 10.55mm&10.50mm/10.50mm lift.
Kelford 182-C 272/272 10.00mm/9.95mm lift
But don’t quite understand how to compare the numbers dunces ones advertised ones vs actual...
Edited by etang789
Looking at these:
Kelfors 182-C 272/272 10.00mm/9.95mm lift
But don’t quite understand how to compare the numbers dunces ones advertised ones actual...
They are both advertised duration.
I would think at this stage more development has been done by kelford than tomei.
On their website they haven’t showed anything new thou. Emailed them about that 182-X 260 custom cam
Let's rephrase that to more development in the last 15 years. Tomei are of the vintage of t51 and t04e turbos and old heavy dual valve springs . The world has moved on and cars are now running ethanol, single beehives and extremely efficient turbos. I'm not saying kelford has changed the game but things like the split lobe 274s would likely suit the modern engine better.
Do you have the beehives on your setup?  you must be rich.  Tomei A work on pro 270 10.8 just fine. Not over sprung and kind to the running gear.
yea they would be, but if you want a more agressive cam ramp they won't do the job. duration and lift doesn't tell the full story about cam design. there is another metric of the cam that is the average lift over the duration that tells more of the story about the cam profile.
also, worth noting the Tomei cams quote the lobe height and kelford quote the net lift. so they're both a 10.8mm lobe cam.
Edited by burn4005
Both Tomei and Kelford quote net lift(Kelford)  and valve lift (Tomei) which is the same thing mate. ie Cam lift - clearance
Unfortunately no one quotes you the area under the mountain which is "secret" , unless you buy me the Kelford cam and i will measure it and tell you as I already have the Tomei and a few more.
26_260_1025_32_33.pdf
182-X 260 10.25mm.pdf
Edited by Meathead
incomplete
  • Like 1
Those 182-X are the custom ones that were made for me. @Piggaz check the sheet
Edited by SimonR32
How they working for you?
I asked for a custom 260 and that's what they offered...still not sure.
Out of the 5 sets of cams I've tried they are equal best response.
On moderate boost levels they make the most power (but head is also now slightly ported), on high boost they make the most power (once again head is ported now).
Never apples with apples, but if I did it all over again, I'd be sticking with them
Interesting!   I remember reading you tried the staggered inlet cam 182s?
Is the one you have now the first 260 you have tried and are you running suggested CLs?
Trying to wake my EFR up a bit earlier (260/10.25 Procams)  and tossing up between 182x or some 256 Reimax cams.
Which other cams did you try before if you do not mind me asking?
Edited by Meathead
Staggered inlet were too big for my application (Precision 6262)
We started at centerlines they suggested, inlet got advanced a fair bit on the dyno. Exhaust stayed the same
Which EFR?
Grex unknown exact specs but around 9.1 260 or 264, Tomei Poncam Type B 260, Tomei Poncam Type R 250 and the Kelford 182-S
Which EFR?
Thanks for the info, always good to know.
I have the  8374 iwg, no E85 in Japan. Going to see how far my tuner can go with advancing the inlet next and other way on the exhaust.
If no joy will consider the 182x or some Reimax group A cams (264/9.7) or their street cam (264in 256exh), they run 105 CLs all around with quite a bit of overlap, have good reports over here for coming on well.
What size HG you have 1.0mm?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
