1 hour ago, Lithium said:
Interesting, same as the 9.25mm lift 264s - so to confirm, they are definitely 260 advertised duration?
Yup, there was talk about going a 222/222 and that was actually going to push the advertised duration to 226 but drop the lift down to 10mm
From Kelford
Quote
I personally would run the 226° ones, given their slightly shorter adv. duration (it’s a design and acceleration thing that makes this the case)
Edited by SimonR32
  • 1 year later...
I’m in the same boat as well cannot decide between Tomei or Kelford. Will be using
Borg Warner EFR 8374 1.05a/r and NITTO's 2.8Ltr Stroker Kit. Car will be mostly street so looking for response.
Looking at these:
Tomei Procam 260Degree 10.8mm Lift
Tomei Procam 270Degree 10.8mm Lift
Kelford 182-S 274/270 10.55mm&10.50mm/10.50mm lift.
Kelford 182-C 272/272 10.00mm/9.95mm lift
But don’t quite understand how to compare the numbers dunces ones advertised ones vs actual...
Edited by etang789
Looking at these:
Kelfors 182-C 272/272 10.00mm/9.95mm lift
But don’t quite understand how to compare the numbers dunces ones advertised ones actual...
They are both advertised duration.
I would think at this stage more development has been done by kelford than tomei.
On their website they haven’t showed anything new thou. Emailed them about that 182-X 260 custom cam
Let's rephrase that to more development in the last 15 years. Tomei are of the vintage of t51 and t04e turbos and old heavy dual valve springs . The world has moved on and cars are now running ethanol, single beehives and extremely efficient turbos. I'm not saying kelford has changed the game but things like the split lobe 274s would likely suit the modern engine better.
Do you have the beehives on your setup?  you must be rich.  Tomei A work on pro 270 10.8 just fine. Not over sprung and kind to the running gear.
yea they would be, but if you want a more agressive cam ramp they won't do the job. duration and lift doesn't tell the full story about cam design. there is another metric of the cam that is the average lift over the duration that tells more of the story about the cam profile.
also, worth noting the Tomei cams quote the lobe height and kelford quote the net lift. so they're both a 10.8mm lobe cam.
Edited by burn4005
Both Tomei and Kelford quote net lift(Kelford)  and valve lift (Tomei) which is the same thing mate. ie Cam lift - clearance
Unfortunately no one quotes you the area under the mountain which is "secret" , unless you buy me the Kelford cam and i will measure it and tell you as I already have the Tomei and a few more.
26_260_1025_32_33.pdf
182-X 260 10.25mm.pdf
Edited by Meathead
incomplete
  • Like 1
Those 182-X are the custom ones that were made for me. @Piggaz check the sheet
Edited by SimonR32
How they working for you?
I asked for a custom 260 and that's what they offered...still not sure.
Out of the 5 sets of cams I've tried they are equal best response.
On moderate boost levels they make the most power (but head is also now slightly ported), on high boost they make the most power (once again head is ported now).
Never apples with apples, but if I did it all over again, I'd be sticking with them
Interesting!   I remember reading you tried the staggered inlet cam 182s?
Is the one you have now the first 260 you have tried and are you running suggested CLs?
Trying to wake my EFR up a bit earlier (260/10.25 Procams)  and tossing up between 182x or some 256 Reimax cams.
Which other cams did you try before if you do not mind me asking?
Edited by Meathead
Staggered inlet were too big for my application (Precision 6262)
We started at centerlines they suggested, inlet got advanced a fair bit on the dyno. Exhaust stayed the same
Which EFR?
Grex unknown exact specs but around 9.1 260 or 264, Tomei Poncam Type B 260, Tomei Poncam Type R 250 and the Kelford 182-S
Which EFR?
Thanks for the info, always good to know.
I have the  8374 iwg, no E85 in Japan. Going to see how far my tuner can go with advancing the inlet next and other way on the exhaust.
If no joy will consider the 182x or some Reimax group A cams (264/9.7) or their street cam (264in 256exh), they run 105 CLs all around with quite a bit of overlap, have good reports over here for coming on well.
What size HG you have 1.0mm?
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
