Exhaust help, defects?
Hey guys,
Does anyone have a Tomei Expreme Ti? Its a single exit which can be adjusted to fit the g35...
How is defecting for exhausts, anyone had any issues? I believe this exhaust is obnoxiously loud, and could attract unwanted attention, i.e the police. I have read the regulations for the exhausts here in South Aus, but i couldn't determine if it is illegal. Its very, very loud and is easy to determine as an 'aftermarket exhaust' due to its appearance. I only drive my car 3 - 4 times a week. I cannot risk a defect as all my money is in the car :4_joy:
Please let me know your honest thoughts, on if i should go with this or remain stock as i cannot risk a defect! :)
- CHEERS
https://www.sau.com.au/forums/topic/470401-exhaust-help-defects/
If it is indeed 'very, very' loud as you say, then you WILL get defected. Depends a lot of where and when you drive it too. Even if it was just one 'very' loud, you would be likely to get defected if you drove anywhere near town on a Saturday night or attended any of the cruises about the place where cops tend to congregate and target imports (even with quiet exhausts). Drawing unnecessary attention to yourself is not a great idea if you cannot risk a defect. Fullstop.
Do what I did and get high flow cats, a custom Y-pipe, and delete the muffler from your mid-pipe. Gives you a bit more burble and power, but is definitely not loud enough to draw unwanted attention. Go and see Andrew at AM Performance - he is the best in the business imho.
  • Like 1
Hey guys,
- CHEERS
Why on earth would you change to an expensive,  noisy, defectable exhaust with no obvious benefits? Buy some better wheels and tyres or even a sound system or restaurant meals for better value for money!
If you believe the exhaust is obnoxiously loud, why are you still interested in it? Only obnoxious people (aka wankers) take interest in such items for a street vehicle. They do it because they want to be noticed. Plain and simple.
As I've said in a similar post, concerning custom exhausts:
If you want to extract as much horsepower out of your NA vehicle as you possibly can, get an Akrapovic exhaust system.
If you want a nice note that's tasteful and not obnoxious, get a Megan Racing muffler.
If you want to be a wanker, get a custom exhaust made with tips that can house a whole illegal immigrant family.
  • Like 2
#swag #fkdah8rs #iluvh8rz
(gets defected for having a shit, loud exhaust) #f*kdapolees
Drill holes in your muffler, or space the joints with washers. No need to spend money on titanium exhausts unless you're after instaface likes
  • Like 1
Well.... If the only mod is your exhaust and you get pulled over by the cops and then have to take the exhaust off, then put back on ome exhaust on for the pits. You will be slugged with the pit inspection fee which is about $80????
As long as you don't have any other problems with your car you'll be fine.
:banana:So roll with it until the day comes :banana:
5 minutes ago, vxsr33 said:
You'll get over the obnoxiously loud exhaust very quickly.
Drop your catback exhaust and drive it around for a week. If you don't hate it, go deaf, or get pulled over by the popo within this time then go ahead and install the tomei.
Tomei is out of the picture then :4_joy: I think i will go custom to save peoples ears and my money. cheers :)
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
