Mongoose M80 (pre 2009) security system help
Hello all. Having a major crysis and in dire need of some expertise!
I have a mongoose m80 security system which is a pre 2009 model. My remote is worn and had electrical tape over the buttons as the rubber button mold was broken. this has caused an incident where I had left my car for a day or two and noticed when i had to start it the tape was holding the button to disarm down that entire time. now my remote fails to disarm my immobilizer in order to start the car.
so a brief summary of my attempts to fix this problem.
  • replace battery on remote- no change.
  • cannot disarm the system as I'm the cars 3rd-4th owner and have no paperwork anywhere for an override PIN as mentioned in the systems manuals.
  • cannot re-sync the remote as it requires disarming.
  • the siren is dead so i have no idea what "chirping" it may be making to represent a fault.
  • checked all inline fuses on the module and in the vehicles cab and engine bay for good measure.
  • budget to repair is tight as a nuns bum so cant just buy a whole new system until last resort.
Open to suggestions as I'm ripping my hair out and mongoose help is only open Mon-Thur, but having to work makes it pretty useless atm.
You need a friend who is good with electronics. Most of my cars have needed their remotes rebuilt. As long as the chips on your remote are ok, you should be fine.
Have someone who knows electronics look at the keyfob. Most of the time the switches wear out and break. Do you know if the remote is actually working when you press the button (is there an LED?). This is where i would start.
    • R31 boot how I received the sub, cleaned and today new carpet installed. Thank you Solder!!!!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
