Hey Guys,
This is only a quick update:
I'm elbows deep in wiring, although really enjoying it. Slowly tidying up this loom, I thought I'd share a progress shot:
Also, the fuse/relay box is completely terminated now, here is what it looks like on the inside:
Thanks for reading :)
  • Like 5
Another small guys, finally have the oil cooler lines ran, was a fair amount of trial and error to get them to clear everything, however I'm happy with the end result. Just need a small amount of spiral wrap to use where the hoses go past the radiator/support panel.
There is only a handful more jobs to go, then the engine can finally go in ?
As always, thanks for reading :)
  • Like 2
On 5/29/2019 at 8:56 PM, TimmyMA70 said:
Hey Guys,
The fuse panel, is that an OEM part rewired, or did you buy a bare fuse/relay panel?
The fuse panel is a bare panel which I bought terminals and seals for.
I looked at a few OEM options, however I couldn't find anything as compact and neat as what this system offered. Plus it's IP67 rated - basically water proof.
If you're interested this is their website:
https://store.chiefenterprises.com/bric
  • Thanks 1
Thanks!
Just had a quick look, will read more later but that stuff is sooo cheap! Definitely of interest for a project of mine :)
3 hours ago, MBS206 said:
Thanks!
Very cheap, although excellent quality too ? They're definitely a good thing.
Glad I could help. Any more questions, feel free to ask.
  • Thanks 1
  • 4 weeks later...
Hey guys,
Been flat-out lately, hence why this hasn't been updated in a while. I have been helping a fellow Pulsar owner out with a few mods on his IPRA VE swapped N15 SSS. Removed his 2.5" exhaust and made a 3" 304 grade stainless steel system along with a SoCal 4-2-1 megaphone header.
A couple of snaps:
I've made a 3" intake and rebushed the entire car for him too, was still fitted with the original Nissan bushes 300k kms old...?
  • Like 2
An update on my N14 also:
Engine is in!!
Fitted the gearbox up too, just a mock up at this stage, I haven't fitted flywheel and clutch yet:
Gearbox went it pretty well, although the Elec P/S bracket will need a slight trim on the corner. needs approx 5mm off it to ensure I don't have to remove the bracket when fitting/removing the gearbox
Not bad, considering it was a guesstimate!
The clearance to the DBW T/B isn't fantastic, although using solid poly engine mounts all round, the engine shouldn't move around a whole lot. Approx 20 - 25mm clearance. If I have fouling issue's I'll make up an adapter plate to move the TB around at a slight angle.
  • Like 6
While you still have it off the road have a good look at the rear mount and see if you can reinforce it. I had the energy suspension poly mounts and custom bronze shifter linkage bushings and managed to shear the rear mount where the linkage pivot/support is welded to it. So there is definately some movement there.
I never did improve it, just replaced with a spare mount but i feel that a reinforced solid rear mount, with a solid dogbone at the front in conjunction with the remaining mounts being poly would have had less movement and stress imparted to the mount, with some sympathy to nvh.
Yeah right. I can't say I have heard of that happening before.
I know a few of the APRA guys abuse the gear pretty hard and have broken some things that has never been broken before, even shifter rods.
Was that under normal street conditions?
Ten years as a daily driver and tracked various places about a dozen times a year. Hill climbs, street sprints, drags and such.
I wasnt exactly easy on it at the track. I went through four boxes as well. Axle tramp is a real bitch.
Yeah gotcha. Wow, 4 boxes is impressive! ?
On 01/07/2019 at 5:14 PM, Dose Pipe Sutututu said:
Way too cool, keep up the good work!
Thanks man! Sorry, I missed your comment the other day!
I'm itching to finish it, although have to reign myself back in and just remind myself to take my time with it. :)
21 minutes ago, TimmyMA70 said:
Took a quick snap this afternoon.
Almost finished the body loom for the headlights, indicators, foglights and parkers ?
That is some VERY clean and tidy wiring!
Where did you get the wrap?
  • Like 1
Thanks man! Really appreciate the words. Alot of time has gone into it, as with any project.
For the body loom I used the self closing braided wrap from Jaycar. Which is pretty good stuff and easy to work with.
The engine loom is getting a higher temp rated braid, obviously a bit hotter around the engine than on top of the chassis rails etc.
  • Like 1
3 hours ago, Leroy Peterson said:
Good job. I did engine harness only... Couldn't be bothered doing the rest of the engine bay or even paying someone to do it emoji14.png
Thanks man ?
With the extensive rewiring with my fuse box, I had to reloom and conduit the body loom after stripping all the redundant wiring out if it anyhow. So decided, no time like the present ?
Thanks, I'll have a sneak peak.
I'm meant to be doing the dodgy budget build to just get mine going but this is Such a clean build that it's inspiring, and I'm thinking I should take the time to properly mount and clip things, and even give it a respray :(
  • Haha 1
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
