No Crust Racing Posted December 2, 2019 Share Posted December 2, 2019 Will you be there when it gets tuned? So we can see a video? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920628 Share on other sites More sharing options...
TimmyMA70 Posted December 3, 2019 Author Share Posted December 3, 2019 I'll just leave these here. Unfortunately I had to work when the tune was finalised, however Benny did do a baseline run for me when I was there. Made sure everything was safe, which it was and ran it up. It was 124fwkw when I took it to him. So this is the final result. 20191202_162709_1.mp4 3 Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920671 Share on other sites More sharing options...
No Crust Racing Posted December 3, 2019 Share Posted December 3, 2019 Sounds good, nice linear power. Should surprise a few other NA bois. 10 points to me for guessing the range correctly. No points for the person who said 180 something kw lol Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920672 Share on other sites More sharing options...
TimmyMA70 Posted December 4, 2019 Author Share Posted December 4, 2019 On 04/12/2019 at 7:15 AM, ActionDan said: Sounds good, nice linear power. Should surprise a few other NA bois. 10 points to me for guessing the range correctly. No points for the person who said 180 something kw lol The video does the sound absolutely no justice at all! That intake sound was making my chest vibrate. Was probably the best moment I've had with my cars, seeing it being revved like it should on the dyno and being able to actually hear it only 3m away. The way the car drives now, it feels alot more powerful than the 132kw the dyno says... maybe I'm just butthurt from the final figure? ?? A 1/4 mile trap speed should clear up the power figure a little better anyhow ? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920734 Share on other sites More sharing options...
No Crust Racing Posted December 4, 2019 Share Posted December 4, 2019 Why hurt? It's a 2L NA engine that's how many years old tech wise? I think over 130fwkw is very good given there are still 4 cyls being sold new right now that make less at the flywheel. Plus you know you can also put a small turbo on it later to really wake it up and make an easy 200fwkw, which would be an absolute hoot given the VVL head will mean bugger all lag on a T28 size turbo. Enjoy your hard work. Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920735 Share on other sites More sharing options...
TimmyMA70 Posted December 4, 2019 Author Share Posted December 4, 2019 18 minutes ago, ActionDan said: Why hurt? It's a 2L NA engine that's how many years old tech wise? I think over 130fwkw is very good given there are still 4 cyls being sold new right now that make less at the flywheel. Plus you know you can also put a small turbo on it later to really wake it up and make an easy 200fwkw, which would be an absolute hoot given the VVL head will mean bugger all lag on a T28 size turbo. Enjoy your hard work. I was probably 'hoping' since my crank is only driving the alternator that it would free up another few kw. However the thing absolutely hammers. It isn't scary fast, obviously. However the power vs chassis is very well balanced. I do have another engine in the pipeline with alot more compression, larger cams, alot of head work etc etc. So we'll see how that progresses. I'll enjoy this over the next 9 - 12 months before I finish the other engine ? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920736 Share on other sites More sharing options...
No Crust Racing Posted December 4, 2019 Share Posted December 4, 2019 Good. Goal of what? 160-180? Still a lot for a 4cyl NA. Or are you adding a spooly boi. Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920737 Share on other sites More sharing options...
TimmyMA70 Posted December 4, 2019 Author Share Posted December 4, 2019 25 minutes ago, ActionDan said: Good. Goal of what? 160-180? Still a lot for a 4cyl NA. Or are you adding a spooly boi. Goal of 150 - 160ish on Benchmark Solutions dyno I think would be somewhat realistic. Depending on a few factors, final compression ratio will dictate fuel I'll be running. Ultimately I'd prefer 98 for simplicity, however I'm not against the corn juice. I have alot of mates asking me, egging me on to go turbo, a few things hold me back there. Driveline is #1 these gearboxes are ordinary at best when it comes to turbo torque, there is a couple of bandaid fixes, although nothing I'm that interested in. Emissions is #2 I really wanted this to fly under the radar, hence N/A, slightly lowered, understated outside. When I add a FMIC, turbo choo choo's etc it makes it stand out a little more. N/A screamer #3 it's a passion of mine too. I like the challenge of having no forced induction to rely on to make power, there is nothing quiet like the sound of an N/A car at 8k too. I recently had a mate drive the N14, before it was tuned. He's all about forced induction. He said to me, this thing doesn't need a turbo man. It's so well balanced in power/weight and also the perfect mix of street/track setup. That came from a guy who turbos everything he owns and also before it was tuned, so no big revs. Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920741 Share on other sites More sharing options...
No Crust Racing Posted December 4, 2019 Share Posted December 4, 2019 There's your answer then! 150-160, NA, at 8k, will be glorious 1 Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920742 Share on other sites More sharing options...
TimmyMA70 Posted December 4, 2019 Author Share Posted December 4, 2019 5 minutes ago, ActionDan said: There's your answer then! 150-160, NA, at 8k, will be glorious I really think so too! It won't be for a while. I plan on enjoying what I've got here, I'd like to do some track days in the new year and maybe a couple of runs down the 1/4 before Xmas. We shall see though ? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920743 Share on other sites More sharing options...
No Crust Racing Posted December 4, 2019 Share Posted December 4, 2019 All sounding good. Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920744 Share on other sites More sharing options...
TimmyMA70 Posted December 8, 2019 Author Share Posted December 8, 2019 Have done 1000kms in total (untuned and tuned) since the engine went in, so wanted to do an oil/filter change too. Threw a spanner over a heap of things to double/triple check everything. It's all looking pretty good though! I'm just enjoying being able to drive it, honestly. 2 Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7920863 Share on other sites More sharing options...
DivHunter Posted December 11, 2019 Share Posted December 11, 2019 Really enjoyed reading this build, very nice work. 1 Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7921011 Share on other sites More sharing options...
TimmyMA70 Posted December 12, 2019 Author Share Posted December 12, 2019 3 hours ago, DivHunter said: Really enjoyed reading this build, very nice work. Thankyou very much mate!! Appreciate you taking the time to read it ? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7921035 Share on other sites More sharing options...
TimmyMA70 Posted December 16, 2019 Author Share Posted December 16, 2019 So this happened.. decided to go and do a run down the strip yesterday. See what it'd do. 1 Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7921338 Share on other sites More sharing options...
Furball1982 Posted December 16, 2019 Share Posted December 16, 2019 On 04/12/2019 at 6:15 AM, ActionDan said: Sounds good, nice linear power. Should surprise a few other NA bois. 10 points to me for guessing the range correctly. No points for the person who said 180 something kw lol I get excited by na pulsars, what can i say ? What times did you get at the strip tim? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7921339 Share on other sites More sharing options...
No Crust Racing Posted December 16, 2019 Share Posted December 16, 2019 How many kebabs did you win? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7921353 Share on other sites More sharing options...
TimmyMA70 Posted December 16, 2019 Author Share Posted December 16, 2019 12 hours ago, Furball1982 said: I get excited by na pulsars, what can i say ? What times did you get at the strip tim? I did a best of a 14.17 on this occasion. I believe a high 13 would be possible, taking into consideration: - hot day - fresh setup and not alot of opportunities to practice launching - not really setup for the drags - a better driver, being fresh, I was pussy footing the launch a tad. 1 hour ago, ActionDan said: How many kebabs did you win? I won zero kebabs as not hectic enough Uleh. Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7921357 Share on other sites More sharing options...
No Crust Racing Posted December 16, 2019 Share Posted December 16, 2019 Any onboard? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7921359 Share on other sites More sharing options...
TimmyMA70 Posted December 17, 2019 Author Share Posted December 17, 2019 2 hours ago, ActionDan said: Any onboard? I've got some videos on the GoPro I haven't gone through yet. Although my wife came down with me and took a heap of videos which I'll upload today at some stage ? Link to comment https://www.sau.com.au/forums/topic/470419-tims-1992-n14-sss-build/page/13/#findComment-7921378 Share on other sites More sharing options...
