14 hours ago, TimmyMA70 said:
I'm a fitter/machinist Dan. I have helped other people out previously with different projects along the way. I love helping people, however the biggest reward is the ones who truly and genuinely appreciate your time.
The last guy I helped I realised the extra cash is just a sweetner, as unfortunately the appreciation was more of an expectation... I struggled alot with motivation.
However the guys who give good feedback, it honesty wouldn't worry me if I got paid or not lol
Thanks for the feedback and compliments as usual mate ?
OK so as long as I'm really appreciative you will come to my place and finish my car, sounds good. Hell I'll eveb fly you down here ;)
Quality makes sense given profession.
11 hours ago, Burger said:
"12 Primera Street" I see what you did there.
You like that? ?
Sounds good to me man! Lets make it happen ?
I've always been interested in custom car fabrication/sheet metal work etc since I was an apprentice. Did an advanced welding course to learn some more about tig welding and the sheet metal, I just make up as I go along.
6 hours ago, ActionDan said:
Maybe I can have SAU build my car.
Timmy can build and fab, @Dose Pipe Sutututu can tune it, and we can do a GoFundMe to pay for it all lol
Oh shit! Here we go. It's happening ?
You get a free car build, you get a free car build and you and you ??
Never thought of a gofundme for something so important! ?
6 hours ago, Dose Pipe Sutututu said:
and while we at it, we can fund the tuner (me) a F30 335i M-Sport with a factory LSD lol...
I will contribute to that a fund a built R33
While we're all in the giving mood! Why not?
Yeah it works well, I give my R33 to the fund, somehow someone trades/strips/sells that and turns that into a BMW for me, and i"ll tune the car, and you get paid for fab work :)
All the extra cash can go into our pockets.. what an idea, just as good as that LMCT plus site!
What could possibly go wrong!?
Very minor update.
It drives. Drove it approx 10m out the back to give it a wash.
Still a few things to sort out, like rusty rotors, ordered the rest of my exhaust components today, a dual flow meter setup for my tig regulator so I can back purge this exhaust, double check everything and off to get a tune.
Thanks for reading ?
  • Like 1
Dyno when?
I'd like to say early November. I've got a weeks holiday coming up, so unfortunately there won't be any progress then as we're going away.
I'd estimate 3 or 4 days to make the exhaust, back purging everything as I go, including modifying the engine crossmember for clearance.
Another few hours in a wheel alignment (currently in track setup) too before I trailer it down there, so then I can drive it home once finished.
4 minutes ago, ActionDan said:
Which page/post has the negine specs so I can review first lol
Oh and what dyno does he run.
This engine is a stock P12 SR20VE. Stock cams, stock head, springs etc. Stock bottom end. However has been shimmed to 0.01mm factory specs.
Engine is only running the alternator, no P/S pump, water pump or A/C
4-1 to 3" collector headers
3.5" - 3" mafless intake pipe
Haltech Elite 1500
That's basically it man.
This is basically an interim engine, partially to make the car more enjoyable for me and so I can teach the wife (or she can teach me) how to drive on the track lol.
Then I'll finish off the P11 engine.
Jez uses a Mainline Dyno from memory.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
