15 minutes ago, ActionDan said:
MIG, oh and it needs a gun apparently.
A mate who welds said its "a pretty good welder".
I was going to just do the buy a cylinder from bunnings thing.
Mig is pretty good, quiet universal and somewhat easy to use, the hardest thing is setting them up. Most guys just set them up by the sound.
Yeah perfect. They don't offer the 'trade - n - go gas' at my local Bunnings, so Gasweld/Sydney tools are the go-to for me.
  • Like 1
On 17/11/2019 at 8:14 PM, iruvyouskyrine said:
I hear this may be making its way to Newcastle in the next couple of weeks, is that correct?
I am from Newcastle ?
On 17/11/2019 at 8:35 PM, Dose Pipe Sutututu said:
Out of all the builds, all the hectic inshallah GT-R builds, this is still my favourite build
Hahahah!!! Thanks so much man! That means more than you can imagine actually dude. Especially with all the awesome GTR's on here!!
On 18/11/2019 at 8:17 AM, ActionDan said:
Do people still build GT-Rs on here?!
? Hmmm. Not sure! Apparently Pulsar > GTR ??
Since the car has been off the road for so long, the brake rotors had began rust. So gave them some love in the bead blaster and scuffed the brake pads up (figure 8's on a sheet of 80 grit)
Flushed and bled all the brakes, for good measure.
It's getting alot closer to driving it now!
19 minutes ago, ActionDan said:
I've had good success scuffing pads before, same pricess pretty much.
How far away is your tuners dyno?
Yeah it's worked quiet well, spoiler alert... the car is currently driving ?
I've been slack updating this.
Untuned, however AFR's look excellent. Haven't given it a decent rev, obviously, however I'd be happy to cruise on the highway with it. Drives surprisingly well for a map, which isn't even 'SR20 Specific'
The dyno is less than 100kms from me.
Had to slightly modify the front cross member to allow extra clearance for the 4-1 headers.
After that, finally drove the thing!!
Obviously light load, watching AFR's like a hawk.
Drove it down to a mates shop where I did a wheel alignment.. for the street. For now..
  • Like 1
17 hours ago, niZmO_Man said:
That is a nice exhaust, along with the rest of the car
Thank you very much! The outside of the car definitely isn't the best. However that's never been my strong suit either.
I'm planning to have a small amount of paint and panel done in the new year, although I'm not going all out, as the car will be used, not a trailer queen / garage ornament.
12 hours ago, ActionDan said:
Looking good.
Slightly more rear camber? Is that a FWD thing?
Engine bay looks mint.
Basically it helps the rear end hang on through a corner, prevent the back end over taking the front lol.
Thanks man!!!
Update: car is at the tuners now
And a Skyline for all you SAU Junkies 20191202_153734.thumb.jpg.451e0f2a02b6e6b004e48f68ade342a6.jpg
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
