3 hours ago, WantGTR said:
How did you clean the timing cover/intake? Just a quick sandblast?
Yeah, that's the one man. I have access to a bead blasting cabinet. It's awesome for aluminum, although it's a fairly fine grit, doesn't do a great job ripping painted surfaces back. It will do it, just takes alot more time.
  • Like 1
Another update,
Finished modifying the OEM Astra P/S pump bracket to fit the Pulsar, will clear everything great and looks quiet OEM as well :)
Finished modifying the bracket to suit
Looks like it's supposed to live there
After a beadblast and a coat of paint
I'll make some lines up to suit this weekend. My Aeroflow order arrived today :)
  • Like 1
A bit slow on the updates guys, although been slow on progress too.
Anyhow, P/S setup is plumbed in, a few things to tidy up, hose clamps on the return line and waiting on some clamps to secure the pressure line to the P/S rack mounting points.
Oh and wire the unit in of course :)
Here's a couple of happy snaps.
  • Like 1
Hey guys,
Another update, Been busy doing a heap of wiring in the N14, the relay box, which was on the RH side of the engine bay (Drivers side) was in the way,
That happened to be where I wanted to setup my remote oil filter/thermostat for my oil cooler.
So naturally it had to go.
On closer inspection there wasn't a whole lot of relays in that box that I was actually going to use, so with the help of a leco mate of mine we stripped the loom back to basics, assessed what we actually needed and the best way it should be routed.
We can to the conclusion that the Relay box was redundant, as was the fusible link box on the opposite side of the engine bay.
There is a few relays I did still require, plus added a few extra's so the N14 was brought up to date in the way the headlights were wired.
This is the relay box that I am left with.
Circuit breakers will replace the fusible links to keep the whole system simple.
This was the hole I decided to utilise.
Made a bracket/brace to mount the relay box into.
Finished product (painted the primed section of chassis rail where the battery tray was fitted too)
With the lid on.
  • Like 2
Hey guys, another update.
Started setting up my oil cooler setup.
I'm using an Aeroflow AF64-4112 which is an all in one thermostatic oil filter block.
Had to make up a bracket to mount it, so decided to whip out the CAD software (Cardboard Aided Design)
Came up with this:
Once that was made and I was happy with the fit, I bent this up:
Then it was onto the oil cooler mounting.
Went with a 10 row Aeroflow oil cooler. They're rated to 10 bar working pressure, 25 bar burst pressure SR20VE oil pumps are very high pressure and it isn't unusual to see pressure around the 8 - 9 bar.
Also used the Aeroflow mounting kit which made mounting the cooler very simple.
Had to put a bend in the center vertical support to give the oil cooler clearance, put it in the spot where the reo bar will cover it up.
I am waiting on some black bolts to show up for the oil cooler, will tie in much nicer.
  • Like 2
After paint:
I've got some paint to fix up the gouged up paint in this picture too. It was caused by the power steering reservoir being removed to access the oil filter, however unfortunately the OEM NIssan wire hose clamp was scratching the paint up every time it was removed...
  • Like 1
Super neat build mate. Very impressive attention to detail and everythinf you are doing compliments the na ethos - light weight, minimise losses from ancilliaries and rev it to the moon. Having had an sr20de n14 built for hill climbs and street sprints i have a soft spot for this. Mine was the same colour but a q instead of sss. Sold it last year after ten years of daily driving and regular competition use - half a million kms and still unopened block, perfect compression and didn't use a drop of oil.
I have an nm35 stagea with the vq25det and awd now which is its own fun but nowhere near as reliable!
Will be following your progress.
Thanks for the words mate. Appreciate the feedback :)
In my opinion they are quiet an underrated and often overlooked car, I have had a huge amount of fun in mine so far, can't wait to get this chapter finished and get it running again though :)
Just trying to knock over a small project every week to keep it progressing forwards. Currently waiting on a heap of OEM coloured trace wire
to save changing the schematic.
500k kms is a testament to your maintenance schedule as well as the car mate, some guys seem to have all sorts of trouble with SR's, although I believe alot of it comes down to a bit of mechanical sympathy.
Ahh awesome, does the Stag have a build thread?
It was maintained meticulously and oil change done every three months.  Ancilliaries did fail as did gearboxes but thats to be expected. Apart from putting in cams and adjustable cam gears, the motor was untouched.
I would absolutely agree that they are under rated. On a tight and twisty track theres not much for the same money that can hang with them.
No build thread on the stagea, much of the work done has been to bring it back up to a good standard. It was somewhat neglected possibly due to the cost of parts, a lot is interchangable with z33 and g35 platforms but some stuff, particularly some suspension components is unique to the platform. Which tended to be what needed attention.
Its got the basics, coilovers, a 3 Inch stainless exhaust, custom bellmouth dump, big front mount to deal with heatsoak, modified wastegate actuator controlled by an ebc. A bigger trans cooler to suplement the factory one. In the middle of acquiring parts for a 370z front brake upgrade at the moment so i can enjoy it at some street sprints and the like.
Hey guys,
Some more updates, been busy making up brackets and doing a bit more wiring.
I am using an Aeroflow AF49-1012. Only issue is that the N14 and GTiR pump cradle is alot bigger that N15. In all my research, the answer for this 'issue' was to just cable tie the new smaller, high flow pump into the cradle....
I wasn't ever going to do that..
So long story short, Walbro make an in-tank fuel pump insulator, this one worked out ot be perfect. Pump sits in there very snug.
Found a spot for my electric water pump controller. It is a bit of an awkward size to mount in/on or around the dash without being hard to access. So decided the glove box will have to do. Made this mount for it, the loom will be going out the back of the glove box via a wiring grommet and the bracket will be painted black, of course.
Then lastly a bit of a bigger update, finally have my ECU mounted:
This is where the OEM ECU lived. The Wideband module sits underneath the Haltech as well.
The brackets will be removed and painted, black as well. I've still got a heap of wiring ahead of me...
Thanks for reading.
  • Like 1
12 hours ago, robbo_rb180 said:
Great work. Wish I had looked at this build earlier.
All the detail is cool. Going to be quick with that VE motor
Thanks for reading :)
It should be a fun little all rounder once the engine is in, shouldn't be too far off. Just a bit more wiring and I can drop the engine in.
Wow, awesome progress! I love the attention to detail and especially your bracket making abilities (which I envy).
Mine usually is just flat bar from Bunnings hit with a flap disc lol
Thanks man!!
Haha, alot of time in those brackets dude! A few were remade when I wasn't happy with them.
Thanks for the words though dude, much appreciated ?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
