1 hour ago, Seboo_Gtr32 said:
that is true, BUT then comes the law and messing around with you... Austrian laws aint made for such cars....  i just cant find myself putting some high end Future lamps in an old 94 nissan,
Are they really that strict? From what I gathered, <2,000lm discharge lamps don't require self levelling and headlight washers (i.e. the 25W systems). I don't think LEDs come under that.
Not expensive either, if you can get LED single projector (ideally bi-LED) headlights (Prius, Corolla, some Mazda cars I believe) headlights for cheap, then it's simple to bake and create a bracket to mount them.
I actually have a bunch of LED projectors from Japan, so I'll attempt to retrofit one set of R32 headlights.
But hey, I'm sure the Hella projectors would be much better than the ones Nissan used.
16 hours ago, Seboo_Gtr32 said:
is there a extra section for build thread ?
There sure is:
Pop your build progress into a thread here:
https://www.sau.com.au/forums/forum/190-projects-overhauls-and-build-ups/
I am looking forward to seeing more of your cars! :)
  • Like 1
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
