1 hour ago, Seboo_Gtr32 said:
that is true, BUT then comes the law and messing around with you... Austrian laws aint made for such cars....  i just cant find myself putting some high end Future lamps in an old 94 nissan,
Are they really that strict? From what I gathered, <2,000lm discharge lamps don't require self levelling and headlight washers (i.e. the 25W systems). I don't think LEDs come under that.
Not expensive either, if you can get LED single projector (ideally bi-LED) headlights (Prius, Corolla, some Mazda cars I believe) headlights for cheap, then it's simple to bake and create a bracket to mount them.
I actually have a bunch of LED projectors from Japan, so I'll attempt to retrofit one set of R32 headlights.
But hey, I'm sure the Hella projectors would be much better than the ones Nissan used.
16 hours ago, Seboo_Gtr32 said:
is there a extra section for build thread ?
There sure is:
Pop your build progress into a thread here:
https://www.sau.com.au/forums/forum/190-projects-overhauls-and-build-ups/
I am looking forward to seeing more of your cars! :)
  • Like 1
    • The nissan manual says to change coolant every 2 years. Is this still necessary if you're using coolant like Penrite or nulon which has improved over the years? It says it lasts 500,000km which seems hard to believe lol.
    • According to the Muse website, totally different material. The originals were that horrible solid foam rubber that was used for a lot of rear spoiler/flap things, like on Mitsu Galan GSRs. Heavy, and with enough compressibility/flex that any paint on them would crack fairly quickly. The Muse ones are just ABS, which is obviously similar to GTR lower front lip, etc etc. ABS is a good choice if you have the ability to tool up for it. The only thing better might be TPU-RIM or something equivalent. The TPUs were good. Plenty of flexibility (in twisting, bending, etc) but not really in compression.
    • Update 24/01/2025:    Bought a GReddy/Trust Intercooler (crossflow spec-LS) that was meant for a R33 GTST $871 AUD shipped, and a GReddy Profec boost controller $483 AUD, both brand new from Japan. Being honest, I would've thought the intercooler kit was discontinued but I guess not yet. Decided due to funds + time, I'll stick with a nistune on this stock-ish setup ( stock turbo set to probably 10-12psi ) and have it run cleaner ( suspect the 3" turbo back etc has sh*tted on my economy ) for my trip down south soon for the WSBK. Hopefully I can get it all installed and tuned by then. As for who I am getting it tuned with, I will be going with Toshi, (not hearing back from DVS so scratch that). There is also Birrong Auto but not sure if they do nistune installations and if they even tune it... Otherwise, anyone know where I can get my hands on an aluminium intake/suction pipe for an RB25DET NEO?
    • The german cars I've worked on seem to have that issue(in more than just headlights). Mostly where hot, but also just the insulation hardening and cracking in various places. Not abnormal from what ive seen.
    • According to the Muse website, similar material, but not the same. Meant to help with stopping the paint cracking. In saying that, I had genuine ones on my last grt, and never had that problem.   Could you post pics when you get them? Very much thinking of buying the Muse ones over fibreglass.
