ATI Balancer RB26 on RB25?
Hey Guys,
I have been looking at running an ATI Balancer on my New RB30/25 Combo but for the meantime while the engine is being built i want to throw it on my RB25 Neo. Now i have googled the shit out of this and cant seem to come up with a definitive answer and ATI only have the RB26 listed on there website but are all the RB25/26 and 30 Harmonic Balancers interchangeable? m not too fussed if the only difference is Pulley Diameter or offset as that can be corrected pretty easily anyway its mainly if the actual design is different for the harmonics of the different combos?
Cheers
  • Like 1
https://www.sau.com.au/forums/topic/470441-ati-balancer-rb26-on-rb25/
ATI say " We don’t make an application for the RB25 Eric’s performance parts in California modifies our RB dampers to work on the RB25 though. "
So I guess you could buy one and modify it yourself or buy one from California (or just stick an OEM stocker on it).
14 minutes ago, B-rice said:
I'm having the same issue with finding out what balance is should be using. It's a 25/30 my intuition would be to use a 30 balancer. However, the question in my mind is that will the belts match up with R34GTT belts?
Just built a 25/30, (in an R33 GTST S2) and used the RB30 balancer. We don't have aircon, and the alternator belt & power steering belt lined up perfectly. The RB30 balancer has a V-belt groove for the aircon so wouldn't have worked if we still had a/c on the car.
I was worried the harmonics won't be similar for the 34gtt won't match the RB30. I guess the question I should ask is what are the engine harmonics for an RB30.
Could those settings be transferred to a 34 balancer that has provisions for the pulleys I need?
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
