Exedy Twin Disc Install/Help
I just recently purchased an Exedy Twin Disc clutch for my GTR R33 (RB26), and I'm currently in the process of installing it. However, after pulling the tranny, ran into a bit of a problem. The transmission and engine won't mate back together because the fork(pull type) and the output shaft sleeve on the transmission won't let it slip all the way back together( there is about 3/4 inch gap between trans and engine). I was told something about machining the sleeve down a bit, however my local car shop that deals quite a bit with JDM cars, they said it should just bolt right up. At this point I would love some help from the experts here, any ideas on what to do, or has anyone else run into a similar problem? If any more information about the car or clutch is required, just say so, first post here! Car is a 1996 Nissan Skyline GT-R R33 VSpec, clutch is an Exedy Carbon Twin Disc with a lightweight flywheel. Thanks for reading!
https://www.sau.com.au/forums/topic/470448-exedy-twin-disc-installhelp/
24 minutes ago, nicholas_ti07 said:
Im not sure, how does one align a twin disc properly?
there is a clutch alignment tool available, sometimes they come with the clutch kit. it is shaped like the input shaft and keeps the clutch in precisely the right spot when fitting it.
Oh yeah that much Ive done, it's just the fact that the output shaft coming out of the trans, it slides into the splines on the clutch just fine, but it hits that mid plate thats between the two clutch discs, and the clutch fork is also hitting something, done so much research and apparently no one knows whats happening lol
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
