Marcelo Jara Posted May 16, 2017 Share Posted May 16, 2017 R33 harness internal conection HR34 neo swap Dear Sirs, along with greeting and thanking you for accepting my request in your forum, I ask if there is a possibility that they can help or guide me because I do not give the information required to my solution of my project.Detail belowI need to locate the operation of the harness acc ecu from the interior of my hr34 sedan, with the pin out of the motor of an rb33 S2 ...It should be noted that this project is a swap to my HR34 sedan.Attached is an image of the harness that I need to locate its name and performance on the pins.I thank you very much for any input or help and I ask you to apologize for my English since it is not my native language.Greetings from Chile cheers Link to comment https://www.sau.com.au/forums/topic/470452-r33-harness-internal-conection-hr34-neo-swap/ Share on other sites More sharing options...
KiwiRS4T Posted May 17, 2017 Share Posted May 17, 2017 R33 pinouts and R34 Pinouts S2 pinouts.htm R34 pinouts text version.odt Pinouts R34_ecu.pdf Link to comment https://www.sau.com.au/forums/topic/470452-r33-harness-internal-conection-hr34-neo-swap/#findComment-7829945 Share on other sites More sharing options...
Marcelo Jara Posted May 17, 2017 Author Share Posted May 17, 2017 Thank you very much, my friend KiwiRS4T,But to be able to concatenate the connections of the branch it is necessary to have the pin out of the neo rb20, can you help me with that pin out ...?Many thanks to the distanceregards Link to comment https://www.sau.com.au/forums/topic/470452-r33-harness-internal-conection-hr34-neo-swap/#findComment-7830003 Share on other sites More sharing options...
KiwiRS4T Posted May 17, 2017 Share Posted May 17, 2017 6 hours ago, Marcelo Jara said: Thank you very much, my friend KiwiRS4T,But to be able to concatenate the connections of the branch it is necessary to have the pin out of the neo rb20, can you help me with that pin out ...?Many thanks to the distanceregards If you look at the R34 PDF you will see that it applies to the RB20 as well as the RB25 Link to comment https://www.sau.com.au/forums/topic/470452-r33-harness-internal-conection-hr34-neo-swap/#findComment-7830011 Share on other sites More sharing options...
Marcelo Jara Posted May 17, 2017 Author Share Posted May 17, 2017 32 minutes ago, KiwiRS4T said: If you look at the R34 PDF you will see that it applies to the RB20 as well as the RB25 Dear, can you help me to indicate which are the pins to energize the ecu ..?Thank you Link to comment https://www.sau.com.au/forums/topic/470452-r33-harness-internal-conection-hr34-neo-swap/#findComment-7830014 Share on other sites More sharing options...
Marcelo Jara Posted May 18, 2017 Author Share Posted May 18, 2017 (edited) 4 hours ago, KiwiRS4T said: Edited May 18, 2017 by Marcelo Jara Link to comment https://www.sau.com.au/forums/topic/470452-r33-harness-internal-conection-hr34-neo-swap/#findComment-7830057 Share on other sites More sharing options...
