18in Works XT7 rims - Powdercoated Satin Black
Hi Guys,
I have had these Works XT7 rims for nearly 10 years as they came with the car when originally purchased.
The rims are 18x8.5 and 18x9.5 and sit perfectly on an R34GTT with no spacers etc... Ill have to check the exact offset but i believe it was around the +30 mark from memory.
The rims have been professionally sandblasted and powdercoated in a Satin Black to match my engine bay and car theme at the time.
10631153_819500188119906_4367579277799674675_o.thumb.jpg.1461017791755aeebc7f1a9d5812663a.jpg
1272468_819491551454103_223502258470674618_o.thumb.jpg.38ceba23b315128011df6c733ac9c3a4.jpg11194550_819512154785376_5028235203771741646_o.thumb.jpg.132b4e149a40036b1c34f6b291afedfd.jpg
The rims had some rash repaired back in 2012ish (Check my build thread for pics and exact dates as its all in there)... This was when the powdercoating was applied.
Genuine reason for sale, i held onto these for a few years after upgrading the car as i intended on getting another GTT for a daily but plans have changed and i would rather upgrade the race car instead. I currently run 18x10.5 rims all round due to the new widebody setup so these are no longer of any use for my GTT.
The rims are off the car with no tyres fitted, they have been polished and stored in the house for the last few years so they are clean! I have an old set of 275 tyres for the rear i can chuck in with the sale, they were fitted to the car at some stage. I also have the original blue alloy Works wheel nuts, lock nuts and locking key, however they were removed from the car as one or two of the nuts had a damaged thread...
I can get decent pricing on tyres through a good mate, if you are interested in tyres please let me know when you enquire and ill pass on the information. On the front rims i have previously run 235/40/18 and also a 255/35/18. On the rear i have run 265/35/18 and also a 275/30/18 (The 275/30 can be thrown in with the sale at no cost as they are just sitting in a rack).
The rims are located in the Newcastle area. Not keen on shipping them anywhere just yet, would prefer the buyer inspects them prior to purchasing. If shipping must be done it will be at the buyers expense and although they will be packed the best they can be i will not be responsible for any damage caused in transit.
Asking price is $1000 and is not negotiable.
Best method of contact is via PM as it will notify me on my phone and ill get back to you ASAP.
Cheers
Mat
  • 3 weeks later...
Bump, Still available... Now with added tyre options -
$1200 with brand new Zestino 240 treadwear street tyres supplied
$1500 with brand new Zestino 140 treadwear Semi Slick style street/ track tyres supplied.
These Zestino tyres are brand new and are amazing value for money. These are currently available from K Racing if you are interested in purchasing separately.
  • 5 months later...
Price dropped to $800.00 firm - NO OFFERS
With throw in the old 275/30/18 tyres for the rear at no cost as they are in my way.
No tyre offer available with this new pricing as it is cheap for a quick sale! Need to fund a new engine!
  • 5 weeks later...
On 18/12/2017 at 2:43 PM, 34GeeTeeTee said:
Still available.
:cool:
    • Correct, I didn't put GT-R in the same category in this thread, incase I offend anyone. But @GTSBoy  knows my true thoughts on all Nissans.
    • Get more oil pressure sensors. I have 3 purely because trust no-one. It would be worth checking (if not already) if it happens on every shift. Like boring, 2-3 shifts at 60kph making 10kw with no obvious G-force on a shift with mega power. Does it still drop? Does it drop less? What if you shift at 5000rpm or what have you with no load?
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
