Advice needed for RB25 mods and power levels.
Hi guys! Hope all is well.
I just recently finished my project car. Its a R33 GTST with the following mods
- Hypergear At43 Turbo
- Refreshed top and bottom end
- 550CC injectors
- Walbro 460 fuel pump
- Link g4 ECU
- Greddy plenum
- Upgraded throttle body - 4"
- Blitz intercooler
- Straight through 4inch exhaust
- Turbosmart internal wastegate
- HKS pod filter
- Bigger cams
Now I was wanting to ask, is it worth tuning with E85 with the current 550cc injectors? or would 98 be better suited? Also what is a reliable power level I should be aiming for with the following mods?
thanks in advance!
Edited by Redknight
You didn't specify which ATR43 turbo.  they are variously able to do up to 600HP (engine).  550cc injectors are able to support around 550HP on 98 (give or take).  So there is a reasonable match between your injectors and the likely size of your turbo.  You will not be able to run E85 unless you restrict yourself to the ~400HP territory of the ATR43G1, because they won't have the flow needed.
My thoughts?  If you want to play with E85 then f**k off those 550s and put in some 1000cc EV14 based injectors.  It will cost you a little to do, but then the injectors will not be a problem.  if you don't want to play with E85, then just keep them, even though they are likely to be old shitty tech and EV14s will shit all over them from a great height.
As to the power limits.....Most of the mods you have made make no difference.  TB, plenum etc are all of no use at these power levels.  You will be able to make as much power as the turbo can support.  The limits will be imposed by the turbo, the injectors, the health of the ignition coils.  You can make 300rwkW on an unopened RB25 easily enough, plenty on here have done so.  That's up in the same territory as the turbo and the injectors.
Sensible part of the refresh you did on the motor would have to have been a decent head gasket?  And you really should have put ARP head studs in too.  If you haven't, you still can.
  • Like 1
I would likely stick to 98 if you are planning on keeping those injectors but injectors are relatively cheap to replace and will hold back your setup depending on how hard you plan to push your setup. E85 will help you make more power if you are hitting a wall in terms of detonation but will require ~30% more injector at the same power level compared to 98.
No idea what kind of power you should be aiming for as it depends entirely on how much boost / revs you (and your tuner) are wiling to subject the refreshed bottom end to but 300KW+ seems to be an easily achievable number on a stock bottom end for a 25.
  • Like 1
You've already done a fair amount, might as well go a bit further and get some good 1000cc injectors as GTSBoy said so you can run E85.
I have an xpurt 1000cc top feed conversion kit on my r33gtst. idles perfect no issues at all, no different to stock injectors.
  • Like 1
Hey guys! Sorry for the late reply. I'm a security guard so I work long hours :(
Thanks for the great advice! I can't remember exactly the name of the hypergear turbo but its rated at 500hp. I'll take everyone's advice and just tune for 98 for the time being and later down the track ill upgrade the injectors and go E85.
I'm getting the tune done on saturday at Lismore. Ill keep you guys posted with dyno sheets and numbers, because everyone loves that :D
Hey guys
just got back from the dyno!
we made 280kw at the wheels at 17psi boost. Hits full boost by 3900 rpm and 700nm of torque.
will post the dyno sheet soon for you guys to check out. Believe me, 280kw is more than enough on the streets for me. Boosting in second gear feels like fricken warp speed. Its insane how quick the car is.
Edited by Redknight
posting the dyno sheet as soon as I get home. Sorry I'm late guys. Car had to be put back on dyno and tweaked because my stupid turbo manifold studs were loose and caused a leak. ( btw this is happening way too often, even with a metal gasket.
we settled on 272kw at wheels. Posting dyno sheet in a bit.
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
