basically i bought a hole bunch of goodies, one of which is a gtr plenum, where putting a spacer plate between my head and the plenum to match the studs etc, was wondering if this would bring on results as good or better than the greddy plenum for the rb25? I heard the gtr plenum has fins that guide the air into each cylinder as the greddy one doesnt. can anyone confirm this? I also got gtr fuel rail, injectors,reg and pump too. amongst lots of others
https://www.sau.com.au/forums/topic/47046-gtr-intake-plenum-on-rb25/
  • Replies 101
If you have already got the plenum, why don't you actually have a look at it to see if what you heard about it is true?
Also might want to search on this, there was a long thread on this topic a few months ago with pics of both plenums, and how they looked mounted up to the head.
  • 1 month later...
Greaddy being the big company they are, I’m sure with out a doubt they have invested lots of time and research to get the best performance out of a RB25 plenum they why they made one for an RB25 and one for an RB26 because each motor has slightly difference workings.
Your best bet would be to sell the GTR plenum and invest in a RB25 Greaddy one if you really are that keen to change.
Yes Steve, but how do I get multiple throttles onto a Greddy plenum for my Rb25? Either way I'm going to have to do some fab. And I know the GTR plenum works well as a unit. Not sure about the capacity of the Greddy ones either. My car isn't being built for outright power but more so for low down torque/boost response.
Thank you for your opinion Steve. However I want multiple throttles and a front facing plenum that is not too large in capacity. Going for the Rb25 plenum and single throttle will reduce my throttle response not to mention the extra intercooler piping.
Oh and it doesn't matter what you are doing - you have to look good doing it.
Trust me - it will work and work fine. You can tune the car to suit so I am not worried. I have heard flow test results from both plenums and I'll take the GTR one thanks.
Have you ever heard of a GTR plenum flowing unevenly? No I don't think so.
Q for Steve - Yes Zoom magazine found that it lost power in most areas, but can you tell me how that RB20 test applies to my motor? 3lt with modified cylinder head and GT35 0.82 housing? I'll give you a hint - there is no comparison.
i dont think that an rb20 comparison would even be accurate to the rb25. Afew more cc's to play with on the 25 so hopefully it should work alittle better than the results of the rb20 one, however i still dont know anything about the results of the rb20 rb26 plenum thing.
I am with you lukevl, I am also planning on doing this to my RB25 in the next 6months and am not doubting that there will be an increase in the flow. I would almost put money on it and say that the GTR surge tank flows equaly if not more then the Greddy surge. The individual throttle bodies are also good for around a 1000hp, so you wont have to be worring about upgrading to a bigger single throttle body. Also I would rather spend $250 rather then $700+ on the greddy. When do you plan on doing this?.....I was going to make an adapter plate also, and wouldn't mind seeing how yours turns out.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
