  • Replies 101
  • 1 month later...
Oh i think a good contender would have to be the JUN spec R34 GTR
http://private.carsales.com.au/photos/386294.jpg
ps. Was built by speedworks
It is 3rd fastest but had a major engine blowup on the drag strip.
ND4SPD is first Jade fisher is second 34 shares 3rd with the 33 from bunbury.
Long intake runners are a definite advantage for low end and mid range torque
i think this is debatable... since you havent got any data to back this up, i'll refer to what others have already bought up.. the rb20 article in zoom that compared the long runner inlet manifold to the short runner gtr manifold. the graph clearly showed that the short runner manifold had more power down low but lost it up top, where as the long runner manifold was the exact opposite.. in fact from what i remember approx half way through the rev range the graphs crossed, at rpms over that crossover the long runner manifold was up in power and below that crossover the short runner manifold was clearly ahead in power
also something to consider, its commonly known that the greddy manifold for sr20det's gives SFA difference to the stock ones for 99% of cars out there... so what im saying is, and this is my opinion, that the stock ones are damn good at what they do, which doesnt leave much room for the aftermarket to improve on... not until airflow figures go waay past the stock parameters they were first designed for anyways
Interesting reading guys. If everyone had the same opinions about what is best we would all still be driving around in model T Fords.
I don't know if this should be a new thread or not but I have an engine here for my own car and one for a customer, both are RB30 block, RB26 head, neither have any intake manifolding at all. Both will be single turbo, t55'ish. Aiming for around the 700hp or so mark, mine will be auto, mostly for drag use.
So, starting with nothing, what would the people who know use? I'm not so interested in what someone read in a magazine but more some real world knowledge. I have a flowbench here and can test myself but I'd like a starting point which will save quite a few dollars.
Mine was no probs either , bolted up like it was factory - because it is . No offence but that system will suffer reversion problems particularly with big cams . Manufacturers go to a lot of trouble to get performance from sporty cam profiles hence V tech or in Nissans case at the time single throttle per cylinder and slightly more agressive cams . There is virtually no communication between the ports on closed throttle . Single throttle plenum EFI manifolds to a degree join up all the inlet ports and are mild mannered with mild cams only . With that scenario and short overlap cams the trapping efficiency is good . With racier profiles most inlet ports and valves flow surprisingly well in the wrong direction . When there's a physical barrier like a throttle plate blocking the reverse pressure wave its got nowhere to go but back in . If any of you have ever tried to live with the racy cam and single throttle set up it gets very tiresome with your daily driver in metropolitan traffic situations . The GTR Skyline and GTIR Pulsar both use the same style of inlet system , both were homologation specials developed at some considerable cost to Nissan . I think the extreme drag teams go with the big single throttle because for very high revs and airflow its the cheap simple way to go . I've no doubt it could be done just as well with six throttles and an ample plenum . Some claim that manifold absolute pressure load sensing ECU's get better signal from the "Big Log" , SK has examples of more than adequate power levels from Mass Air Sensing ECU's . Its beyond me why people spend more than the cost of a GTR head and inlet trying to re-invent the wheel , not cost effective .
Hey Discopotato,
No offence taken, but just for the record 2 of my freinds both running the same intake setup as myself & massive cams have no problems at all. To be perfectly honest with you i dont realy understand what you have said above, what i do understand is "It works, & works very well" (Very streetable cars, there daily drivers), and also is very cost effective. (My head set me back $500.00, +300.00 for RB26 plenum) please PM me a phone number if you can find me a RB26 head & intake for under 1K. You will find alot of people do this because they dont have the $$ for a RB26 head & intake setup, After all if we all had the $$ im sure not to many of us, including myself would bother fabricating RB26plenum to a RB25Manifold.
:P
Trev
No offence but that system will suffer reversion problems particularly with big cams.
Has anyone calculated the ideal runner lengths to counter inversion pressure waves at the various rev ranges (frequencies) for low middle and high end torque for use with the GTR plenum volume and a range of cam lifts and overlaps? I'd be inclined to consider that plenum as an infinite chamber for ease of calculation initially if you use a single throttle body. Maybe one day I'll get of the fat blurter to make an excel based tool.
Also has anyone considered the benefits of a twin throttle setup a'la the Zoom Excel that responded very dramatically some years ago? Is the throttle body a large enough restriction? My thoughts are to put 2 RB25 throttle bodies on a RB25 plenum equidistant from the centreline.
My personal interest is in a forward facing plenum so I can fit a GTR strut brace, as it won't fit with the current plenum.
Give me the $20,000 software and ill model it:) Problem is even with the right software, the model is only as accurate as the assumptions you have made in modelling it. You can use motion analysis software with functioning valves....or use soem rule of thumb calcs for runner length and diam, which are meant to be a good ball park starting point.
LOL...before all my RB20 probs i was going to extrude hone the std plenum and weld up another throttle body. (To see if with the cams and bigger turbo the plenum/throttle was a restriction?!?!?!0
Had the cables etc all sussed, but then lost interest in thinkering when it became a major drama to get the car back on the road. People say it wont make jack difference, but id still like to try. Notice that the NA RB25 NEO has a single throttle body but is connected to the inlet manifold in two places, ie throttle body is above exhaust cam not inlet cam, and over the rocker cover the airflow splits in two?!?!?!?!?!?!
Id love to be unemployed and try these things out Mon-Fri...cant wait to win Powerball.
Give me the $20,000 software and ill model it:) .
I don't think I'd give you a stale fish to slap yourself with mate (just trying to maintain some contention in the forums) :D Actually just get an employer who will let you get away with buying this sort of product. I almost did but instead we put an armoured vehicle in a wind tunnel with greater than 1/3 blockage ratio. Only cost 200+K when the software would be a lot cheaper.
As I said, the right employer. Maybe time for a job change.
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
