Oh golly, what a bun fight.........
My take on it is this. Multi throttle bodies will give you two things, better transient throttle response, and better cleaner idle with large overlap cams. None of this is going to show up on a dyno at wide open throttle(s). On the road it might feel quite different, and that is where the advantage lies, not on the dyno, or quarter mile times.
For sheer balls to the wall top end horsepower, a single throttle body can be made as large as you want to make it. Throttle response and drivability will not improve. Drag cars have single throttle bodies, and the road racers keep the individual throttle bodies. What do YOU want to use YOUR car for ?
As far as inlet manifolds go, what else are you going to do to the engine, and what is most important to you ?
Long intake runners are a definite advantage for low end and mid range torque. At stock and moderate boost levels they are NOT restrictive as Sydneykid keeps on telling everyone. Air distribution is excellent. If you are planning absolutely massive boost and radical high Rpm power, something else might work better.
The GTR manifold was designed for less restriction, but it also is going to have less low and mid range torque because of much poorer cylinder filling off boost. That DETT engine relies totally on boost pressure to make it go.
I would bet that with stock boost and stock single turbo, an RB25DET will have reduced low and mid range torque, and it will not have the same top end power as the GTR simply because the stock turbo will run out of flow. Although I have not actually tried this myself.
It probably will work better if you are planning to upgrade everything else along with the intake manifold, the engine will then take on a completely different character.
At stock GTR power levels the factory GTR manifold will have near perfect air distribution. The Nissan engineers made it that way by putting in all those ridges, steps, and curves. But if you start increasing the air velocities greatly above what it was designed for, it will all start to go wrong, and the rear cylinder runs lean.
That is where all this nonsense started, guys start running 20+ psi and complain the stock manifold is rubbish. Well, maybe, but it was never designed for that.
Decide what you want it to do, and design it to do that job.
  • Replies 101
Excellent post Warpspeed, I would only like to add one little bit to the above para....
The Gibson GTR's ran the standard plenum and throttle bodies and the only engine dyno sheet I have seen showed 640 bhp at 1.9 bar (28 psi). So if 13 years ago they could get it to work perfectly, run 1,000 kms at race pace, up and down MtPanorama, surely it is not stretching the imagination for us to do the same now. Just the ECU improvement alone is light years ahead. :burnout:
WARPSPEED- Good explanation mate, The reason i have got the GTR plenum sitting in my shed over the Greddy on or custon one of stock runners is because i bought a big package when my engine blew, consisted of afew gtr parts including crank, rods, plenum, injectors and fuel pump n rail, also came with lots of other goodies, for me to get all these goodies at a good price i had to buy the lot. Everything is usable on my rb25 and therefor i have a gtr plenum that i am going to adapt to my head and see how she goes, thats why this thread was started. I understand that for the low-mid range torque its not going to be benificial and maybe not significant gains in top end power i havent a clue but since i got it i am going to use it seem logical? I got head port work, 256 cams therefor retaining vvt, to try n help with the breathing alittle. I think its better to put it on now whilst i have the engine out and in pieces rather than trying to swap manifolds over months down the track when the engine is in the car and driving.
Sweetr33, sounds like you have a plan.
Fitting the GTR plenum just by itself will probably make the engine feel a bit soft down low, and might be a disappointment. But if it is just the very first step in a long range plan that you have worked out, it is probably a pretty smart move.
Are you still running the stock ECU ?
Seen how many Jap circuit race cars have single throttle bodys now.
AS for the oz race cars that was a very long time ago and to group A rules so even if they wanted to change them they can't under group A.
Ask John munro about ND4SPD and you will see its a genuine streeter but we are going to change the car around for a few months to show its tru performance as it has run 142mph down the 1/4 on basic dunlop road tyres wait till we set up the chassis and run semi drag rubber + good fuel and race tune.
Ok Updating, Me and dad went and had a closer look at the gtr manifold. Seems the gtr runners where they meet the head are round where the gtst inlet port shape is sort of like a butterfly shape, Our theory is to chop the standard gtst inlet manifold about 2 inches from the flange to the head, retaining the water cooler feature, which would also make the part where wer need to adapt the gtr plenum also round following so far?
There was going to be a drama fitting the injectors into the gtr plenum, meaning we had to drill holes into the runners and make alloy sleeves to fit the injectors and get the right angle of fire etc, but now with retaining the standard inlet flange we already have hoels for injectors and also a good spray angle with the aid of the inlet water cooling.
Another drama we came across with the initial thought of just making an adapter plate was that the gtst inlet ports are wider than the gtr plenum holes so we would have to somehow taper down the the correct size. Was going to be a hassle so we have decided this is the best way. Let me know what u guys think and know about our idea
This has been done before by many people. The way they do it is as you suggest. Cut all the GTST runners off straight, just before the injectors, and either weld on the GTR plenum direct, or better still, weld on a flat flange plate, and then bolt on the GTR plenum.
There will be quite a bit of grinding and matching because the runners DO NOT LINE UP perfectly. GTST runners are almost evenly spaced, the GTR plenum has the runners spaced in three pairs to suit the three twin throttle bodies. Every runner needs to be moved sideways a small amount. This is not obvious just by quickly looking, but if you look very carefully you will see what I mean.
You will come across the problem that cylinders 3&4 dip down on the RB25 lower runners to make them equal length. This to me seems like the biggest problem.
***Does anyone have an RB20 lower runner section that they can look at for me!!!****
I'm going to have a red face I can tell but... what is that? Some sort of wild mods to the 5th and 6th cylinder?
Nah, #5 and #6 are different to clear the master cylinders, brake and clutch. As you can see they are the same close to the cylinder head, so you can cut and weld on a flange. :)
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
