GTR32 Austria
So, im introducing myself one more time and want to share my european nissan with you guys, wish some honest feedback, pro and contras!!
Sebastijan my name and im living in Austria, kinda sucks but yeah :D not the point of this thread !!! 26 years old and still work as an Truck technican/electrican..
Got The R32 since 2 years now and did some new mods, not that big, just a small things!
At the moment;
rb26 stock bottom end
Apexi cams
Haltech ECU
ID1000
Walbro 450l Fuel pump
Radium Engineering FPR, Fuel Filter, Fuelrail,
Gt2871R twin Turbo, (I know not the best choice for the rb26)
Intercooler, intake, exhaust etc. the usual stage one mods
https://www.sau.com.au/forums/topic/470461-gtr32-austria/
Starting to change the turbos and fueling systems, did also a brake upgrade, went with the 4 piston EVO calipers with an adapter made in Finland, nissan 370Z brake discs on the front
355x32mm and on the rear i let it stock Brembo, with an BM57 brake master cylinder
it was hard do pick a fuel rail.. i dind´t want to get a blue or purple one, didn´t want anything that shiney, i decided to get the whole system from Radium Engineering with black Ultra Flow Fitting, didn´t want the blue/red fitting and/or the shiny rail... i dont like to be attacked by the rainbow when you pop the hood :D
made it work with E85 BUT... they abolished that in Austria !! so thats my luck ...
Turbo water /oil  lines are all flex hoses, looks good and it makes delete that old rubber stuff, plus its easier to work with !
  • Like 1
https://www.sau.com.au/forums/topic/470461-gtr32-austria/#findComment-7829952
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
