GTR32 Austria
So, im introducing myself one more time and want to share my european nissan with you guys, wish some honest feedback, pro and contras!!
Sebastijan my name and im living in Austria, kinda sucks but yeah :D not the point of this thread !!! 26 years old and still work as an Truck technican/electrican..
Got The R32 since 2 years now and did some new mods, not that big, just a small things!
At the moment;
rb26 stock bottom end
Apexi cams
Haltech ECU
ID1000
Walbro 450l Fuel pump
Radium Engineering FPR, Fuel Filter, Fuelrail,
Gt2871R twin Turbo, (I know not the best choice for the rb26)
Intercooler, intake, exhaust etc. the usual stage one mods
https://www.sau.com.au/forums/topic/470461-gtr32-austria/
Starting to change the turbos and fueling systems, did also a brake upgrade, went with the 4 piston EVO calipers with an adapter made in Finland, nissan 370Z brake discs on the front
355x32mm and on the rear i let it stock Brembo, with an BM57 brake master cylinder
it was hard do pick a fuel rail.. i dind´t want to get a blue or purple one, didn´t want anything that shiney, i decided to get the whole system from Radium Engineering with black Ultra Flow Fitting, didn´t want the blue/red fitting and/or the shiny rail... i dont like to be attacked by the rainbow when you pop the hood :D
made it work with E85 BUT... they abolished that in Austria !! so thats my luck ...
Turbo water /oil  lines are all flex hoses, looks good and it makes delete that old rubber stuff, plus its easier to work with !
  • Like 1
https://www.sau.com.au/forums/topic/470461-gtr32-austria/#findComment-7829952
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
    • Does anyone know what the centreline should be for the vct intake cam? On my cam spec card it just says VARI and doesn’t actually tell me what the centreline should be. I had to adjust my exhaust cam gear by about 5 degrees advanced so I’m guessing I would have to adjust my intake as well? Current intake centreline is 119 deg. Iv already asked kelford and they won’t respond, It’s the 246-A 262 cams.  thanks for the help guys
