Wheels are used, they are in good condition other than a Few scratches
And no they do not have tyres on them it is just the wheels only
Should fit, R33, R34 (not sure about R32
Supra
Soarer
GTO
Skyline
300ZX
& maybe 180&200sx
Thanks you
I am located in melbourne area
If interested call
Will update pics soon
Thanks
Also Interstate delivery can be arranged with con note
285s on 8.5s because they are 18s they wont have much sidewall to bulge...i find that hard to believe...
i have 9s and i run 255s but i can go higher than that...
i think paul told me he runs 295s on his 9s but they are 17s...like i said thats more sidewall...
Watch what you say mate
I am no thief
They are of my R33 Skyline
If you have a problem Call me & we will meet up
PH: 0413 330 734
I was just making a lame joke about these "hot" wheels that you had...
We can meet up, but be warned I will DESTROY you *flexes*
Ahahahah, seriously. You wanna fight a person from da intarnetz?
OMGz... if only you were half as smart as you are belligerent!
But yes shouldn't have whored your post. Moderator should probably clean up this mess.
p.s. Is pistols at dawn ok?
EDIT: Just deleted my posts... sorry. I am a bored ****
Guest
