CA18DET Rebuild or engine swap?
Hi All,
Recently my current CA18DET just blew up (cracked piston rings) and overheated.
Ive got a spare engine lying around with unconfirmed kms (obtained from a previous purchase).
My question is what would be the best path for just getting the car going again (and reliably).
Should I refurbish the engine back to OEM? or just bolt her up with a new head gasket?
Also, if anyone knows who is decent with CA's in Brissy, let me know.
Cheers
https://www.sau.com.au/forums/topic/470485-ca18det-rebuild-or-engine-swap/
  • 3 weeks later...
As one of the rare people still using a CA, you should give it all to me.
  • What is this car? daily? track? drift?
  • What do you want to do with this car?
  • What power do you want from this car?
  • What's your budget?
If you have a spare bottom end, you could easily get it inspected by an an engine builder to assess condition. Then make a call about whether you can just slap a head gasket on it, all your old shit and go for gold.
If it's a track car/you have a decent budget, then you have lots more options (and should do certain things).
In stock tune, they do not "just blow up" and crack rings. Mine has done 146ks on a stock bottom end and is still being abused on the track with a mild 200rwkw setup. They are strong motors for the age/design. I did replace a head gasket, but that was due to my dodgy tuning learning adventure.
Find the root cause, if it was heat related then you might have a fuel delivery issue leaning it out or an overboost issue leaning it out.
Stock ECU? Stock turbo? Lots of questions.
  • Like 1
:D CAs are pretty cool little nugget. I rebuilt mine in 09, it made 314rwkws on Pump 98 fuel using an old ATR43G4 turbo internally gated.
And I sponsored a drive whom also had a built CA18det that made 344rwkws on P100 fuel using the same turbo externally gated.
Lovely numbers I must say
I've decided to go a fully forged bottom end. Keeping the s15 turbo for now. Targets should be around 300hp at break in and after 400+
We figured out after a bit of looking that it was a boost spike that blew the piston rings.
I think you'll struggle to make 300rwhp on a GT2560 without some reasonable cams and even then I'm not sure.
You could try running it at 20psi+ to get there, but don't expect turbo to live long.
I run the same turbo and they are pretty much out of puff by 16-18psi max. Check the comp maps.
  • Like 1
Yeah I'd agree, at the end of the day its just a number. My main goal is a well balanced and responsive engine.
Long term a set of good cams, injectors and a decent turbo should do the trick, maybe even an ATR43G4, who knows.
Plenty of guys (well less and less in fact) here in France runs the CA18 with a gt2560r and the max reliable boost is about 18psi, anything beyond that and the turbo is just breathing hot air up top. Bloody good turbo for smallish/slowish track but it runs out of puff quickly. I agree that you'll not see 300whp with this turbo unless in kill mode, 280whp is more what it can make.
Cheap way for the cam is installing an exhaust cam at the intake to get a bit more lift or a CA16DE intake cam to get a bit more lift and duration. But to be honest don't bother, there is more to be gained with other breathing mode and a smart turbo choice than slapping cams on it.
A mate is using a GT3071 (not sure is it's the cropped 56.5 turbine or the 60mm one) internally gated on his stockish CA. The only upgraded internal parts are metal headgasket and ARP rod bolts. He was running 24 psi (E85) for years (mainly on track) and the oil pump let go last year.
  • Like 1
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
