Sounds like rod knock ??
Hey guys.
My r33 gts25t is playing up. Was converted from auto to manual and runs the factory TK auto ecu. It was running out of power at higher revs (approximately 4500-5000rpm) as the VCT wasn't working since the VCT needs the auto in drive so it will switch on.
So i connected the TJ manual ecu and VCT starts working. The next day the car started misfiring at start up so i change it back to the old auto ecu. Still misfiring.
Now it feels like its running on 5 cylinders most of the time and sometimes 6 cylinders. While on 5 cylinders it has a knock coming from the firewall end but on 6 cylinders nothing. I replaced injectors, spark plugs, coil packs, fuel pump.
Any advice please thanks
https://www.sau.com.au/forums/topic/470496-sounds-like-rod-knock-%3F%3F/
