Garrett GTX3582 + Turbosmart 45mm Gate + Dump pipe + Bolt on + Buy please
GTX3582, pretty low kms (less than 10K), working fine, boosting well, no shaft play. Has a Turbosmart 45MM Hypergate welded into the housing (T3 0.82) by Scotty Fisher (www.scottyscustoms.com.au) which holds boost like nothing else.
Have been able to really just choose any amount of boost and it'll just hold it, I've ran between 4PSI to and including 28psi on the same spring. Have extra springs for the Wastegate if you want to be super hardcore. Also included is the dump pipe, but you'll need a flange to fit it to your exhaust (at the cat end) as it was custom made. I do *not* have the screamer as I have re-used it for my current setup.
Dump is a really nice 45deg angle pipe, fits a skyline no issues whatsoever. Suspect it'd fit most things. Seems to flow really well, made of stainless.
This will bolt directly to a RB25/20/30 stock manifold and it will fit. I would recommend a spacer to be 200% sure, as I just used 3 gaskets which is quite a bit ghetto but never leaked. Comes with the second hand lines I was using if you want them.
$2000. Would prefer local pickup/delivery but I can ship it at buyer's expense etc. Would prefer not to seperate as it's a good little package as is for a RB30 or RB28 or RB25 if you really are all about that lag and unsafe levels of power for a stock engine.
Yes it looks a little used, because it was used and actually works entirely fine as opposed to sitting around being hard parked.
  • Like 1
100%. Wasn't actually very close to the strut at all. Bigger issue was touching manifold with the housing rotated in a certain way. Fixed easily with a spacer though I just used more than 1 gasket as I had that on hand at the time. I even have 3 gaskets if you don't want to buy a spacer lol. Seemed dodgy as, but it worked for me, and never leaked.
I assume it'll fit other cars, mainly cause the R34 has less room than the other 2 there with ABS and heater hoses etc. Which this also clears fine.
Note: on RB28
Note: also auto
Note: those things also for sale if keen lol
Note: link doesn't seem view able on phone app. Works on PC!
  • 3 weeks later...
Up  you go.
Would much prefer to sell this to someone who can use it as intended/use the dump pipe etc.
Otherwise all the extra stuff will go into a bin and that would be a shame.
  • 4 weeks later...
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
