Rb20det running rich after injector swap
Hi guys pretty new to this forum need help with my 1990 HCR32 Skyline. So i bought this car it had RB20DE with auto tranny i swap the gearbox to manual than replaced the motor to RB20DET using the DE harness plus the injectors. It worked fine with stock boost of 5 psi. Than i installed a bigger turbo (to4e) the car car started to ping on boost above 7 psi i changed the ecu from a rb20det very little difference was made so i went on to change the injectors to 550cc (mostplus brand) now the car runs so rich and worse than before where it used to run with rb20de injectors. Can someone guide me on the next steps so that i can get to go up till 10 or 11 psi of boost and dolve the over fueling issue . Also the why is the idle so rough. The spark plugs are so covered with carbon deposits i guess thats due to running rich. Any suggestions??
so i'll just clarify
" The spark plugs are so covered with carbon deposits i guess thats due to running rich. Any suggestions?? "
you've put bigger injectors in, haven't done anything to adjust the tune, and now it's running rich?
as Trex said...probably wheel bearing, or Johnson rod.
Your car will never run properly as the ecu you are using is not tunable. You need either an aftermarket ecu or at least a Nistune chip. If you are feeling lucky you may find Nistune or someone else will put a tune on the chip that roughly matches your set-up although i think you will need at least a Z32 afm. I assume you have fitted an intercooler of some sort? Does someone like Max Sols in Suva have a dyno?
  • Like 1
O.K
I will explain this
We are going to use some random injector values to make it easy
If your stock injectors are 250cc and at 3000rpm they are injecting at 50% of their maximum - 125cc injected
If you then put 500cc injectors in and dont change the tune to tell the ECU that there are bigger injectors in, guess what happens - 3000rpm you get 50% of the maximum - 250cc injected
It needs a tune
It needs alot of things by the sound of it
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
