Hey all not sure if this is in right section but i have a problem i have a r34 skyline and it has a high flow fuel pump directly wired to battery. When you first start it in morning cranks and fires stright away but when you drive it somewhere like i went to servo other day and turned it off and then tried to start it again and was very slow cranking like the battery was going flat so i changed the battery thinking it might have been old but nope its got the stock size 430cca do i need a bigger battery or is something else? Alternator? Its been doing it since i have owned it and sometimes it doesnt even start just cranks slow then clicks like battery hasnt got enough kick or is flat. Any help would be great thanks.
Aaron
https://www.sau.com.au/forums/topic/470512-battery-problem/
Have you checked voltages with the car off, cranking and running?
Test those and report back
Im going to suggest it might be the starter motor if it is worse when the car is hot. And you have changed the battery. Interested to know the charging voltage (with car running)
  • Like 1
https://www.sau.com.au/forums/topic/470512-battery-problem/#findComment-7830564
As 89 CAL said starter is likely, but I would also check the earth straps, esp. to the block.  Starter motors can go lazy if the motor has a poor earth.
Easiest way to check this is [is your battery in the boot?] use both jumper leads end to end and connect from your negative terminal to the motor direct then try starting again.  If it works then its an earth strap, if it doesn't then its probably the starter motor.
https://www.sau.com.au/forums/topic/470512-battery-problem/#findComment-7830743
Pretty sure the $20 is mine. I was first in with starter motor [emoji108]
https://www.sau.com.au/forums/topic/470512-battery-problem/#findComment-7832667
27 minutes ago, 89CAL said:
No way - your starter motor suggestion was before the $20 bet was placed. I'm claiming it as I called him out on his fuel pump comment:) I think I'll buy about 12 litres of E85 (unless the price has gone up again) to run through my fuel pump.
Maybe he'll give us both $20...
https://www.sau.com.au/forums/topic/470512-battery-problem/#findComment-7832674
On ‎25‎/‎05‎/‎2017 at 8:48 PM, breaker1845 said:
Twenty bucks says its a weak earth to your fuel pump. Fix that problem and it'll crank everytime if your battery/starter is good.
breaker18445 he send it me guys............it is offishal, you want $20 please to open visa account in your name and send me direct to the numbers [card number, CCv, and pin] and me will collect release $20 to you of eech
https://www.sau.com.au/forums/topic/470512-battery-problem/#findComment-7832774
    • The 32 still sits untouched with the broken gearbox. So a little off topic but not worth having a whole new thread. The daily starlet has gotten back on the road after 9 months. Suspected blown HeadGasket at a track day resulted in a bit of scope creep rebuild. The motor got a full tear down, pressure testing, machined for MLS HG, ARP head bolts, new bearings, all new seals etc also noticed some fatigue on the stock exhaust manifold so obviously the answer was a steam pipe manifold and highflow turbo. The exhaust was also looking tired with some rust holes. So I got a slightly over kill system made up consisting of Vibrant resonator and muffler with a highflow cat. The new highflow turbo had a larger inlet so instead of adapting the old intake got a case of the might as wells and had a nicer alloy intake made After the run in was finished i bought a (probably considered retro/vintage) EBC becasue "might as well"
    • Pretty stout result. How much boost? Anything left in it?
    • Just dropped the car off at MX5 Mania to install the intake plenum and give it a little retune  My impatience hates the waiting game
    • SAMSONAS      Just saying      U know and we know U wanna     Just a matter of time....
    • This is kind of what I expected given the use case. I took my liners out for track days too.... It makes me consider just getting a diffuser and not bothering with the arch liners themselves. For the most part I would like to avoid water/mud/jank splashing up from under the car onto the bottom of the engine, lines, wiring, etc etc. (but brake ducts are cool too). Especially given this post on SAU here: Where it's implied you have to cut them because the actual tub is different? Which is pretty damn worrying because that is where the liners rub in a GTR with wider wheels... I definitely won't want to pay $2000 for plastic then cut them up. It also means said wider wheels rub on the tub in a GTT? FML. That said, I have found some evidence someone ran a 295/30/18 without scrubbing these liners. (and by extension.. the tub).
