C34 Series 2 - Gremilin with starting
Hi All,
I have a frustrating problem. A few weeks ago my car was broken into, barrel lock ripped out and battery flattened. Fine, charged battery and now I start the car with a screwdriver.
My issue is the car doesn't start every time now, seems to be quite random, probably starts 50% of the time. When it does start, it roars into life in well under a second and runs like a clock. When it doesn't it just cranks and cranks without a hint of getting started, which made me believe it was a sticky relay or dodgy earth. I have since replaced or swapped around all the relays and inspected and cleaned all the earths i could find (about 5 in engine bay and one in the driver's kick panel). Oh, and I can hear the fuel pump working regardless of it not starting. Battery voltage is 13.2v, but the starter still sounds fine with this. There are also no ECU codes.
I have searched far and wide and can't find a solution. Would anyone have any ideas on what to do next?
Should I just get an auto elec in?
Pulling my hair out!
https://www.sau.com.au/forums/topic/470523-c34-series-2-gremilin-with-starting/
  • 4 weeks later...
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
