My turbo started to be laggy and unresponsive :(
Hey guys.
cut long story short. I've just had my car dynod 2 days ago and made an impressive 272kw at the wheels on 98. Car drove pretty well and was quick. Although I noticed when driving home on the M1 shortly after the dyno run, my car would be inconsistent with how the boost would come on. This was especially evident in 3rd gear as the intake would sound really loud but the car would not pull.
I didn't think too much of it, only until today my turbo started to feel really damn laggy. I would have to push the accelerator all the way to the floor for the turbo to kick in :( And I can't really hear the turbo spool like it usually does.
The last time I had this issue is when the turbo manifold bolts were loose. I had tightened the bolts and the car was transformed. The the boost came on hard and you could hear it spool nice and crisp. So I thought it would be a good idea to get a mechanic to add a metal gasket between the turbo manifold.
Once I had the metal gasket installed the car never really felt the same and im not too sure why? Also the bolts were constantly coming loose no matter how many times I would try and tighten them down. Do you think this could be the underlying issue guys?
I have a map sensor so would a boost leak still cause sever turbo lag?
Any help would be much appreciated.
When the gasket was replaced was the turbo looked at?
If you don't have lock tabs the nuts will want to undo always.
A Boost leak still causes issues even if you use a map sensor, it just means the fueling isn't thrown right off. I would definitely check the easy things first.
Boost leaks, dead turbo etc
Thanks for the reply mate.
turbo is brand new and in good condition. I will be getting some lock tabs to see if it fixed the problem. Its driving me crazy!
1 hour ago, Trex said:
boost leak on a map would hunt idle, stutter/shudder under boost, and feel slow.
What ecu are you using? Do some logs and post them here
Hey mate
I'm using a link G4 ECU. My idle dips fairly low and almost stalls at times when I bip the throttle but I do have a forward facing plenum and big ass throttle body.
I had a look at my boost gauge today and I am starting to make positive boost pressure with my throttle all the way down to the floor and at about 4500rpm its at about 5 psi and will increase boost from there. Also my gauge is reading - 20 and its usually at - 18.
Usually I can get a nice vacuum and spool with not even quarter throttle and by 3500rpm im at 8psi. So something is definitely not right.
Its a new turbo so I doubt its blown? :( Ill see if I can post logs for you guys. I'm willing to send someone $50 from pay pal if anyone can solve this issue lol.
Edited by Redknight
I had my car tuned on a dyno once and 2 days later I had no boost and was very laggy. I took the cat off for a look and it was blocked up.
This could be your cause. Undo 2 bolts and shine the torch in there.
Update
Driving the car home from work this morning, I noticed my turbo was spooling normal again and had my power back. I parked the car to get something to eat for 10 minutes. Start the car up again and turbo goes back to being silent and can hardly hear it spool, feels like I have the handbreak up when Im boosting and extremely laggy. Also a strong fuel smell :(
Checked the exhaust and no signs of it being blocked. Exhaust place checked for any leaks with a stethoscope and couldn't hear any leaks. I have no idea what else to do :(
I am willing to pay anyone via paypal if someone can solve this issue. Its least I can do to get my baby driving like it should. I have spent so much damn money on this car and I expected it to be right :(
do you guys think its tuning related? I had it tuned at dare motorsport at Lismore NSW.
edit: The tuner added a 3 port solenoid to control boost. Would this cause any of the following issues if it was faulty?
Edited by Redknight
  • Like 1
Reeks of fuel, faulty plug or coilpack?
Whens the last time you changed the plugs?
I had a coilpack fail and it was real laggy but you could tell something was wrong just low speed driving
Do you have a wideband? Is it possible someone has increased the fuel pressure and thrown the tune out (richer)
Thr fact that it smells fuely when it plays up would make me want to explore that further - too much fuel injection or not enough air getting into the engine
As above, i would take it to the tuner, especially if you dont have a wideband installed. Could take him 5mins to work it out
  • Like 2
UPDATE #3
Omg my exhaust sounds absolutely horrible today. It sounds really tingy or maybe slightly like a tractor? It just sounds terrible and nothing like an RB25. Also the fuel smell is so bad its stinging my eyes while I am driving. Boost lag is horrible and I can't even hear the turbo spool until I get to 5000rpm then it hits 17psi.
Would coil pack issue cause these issues? or maybe stuck wastegate? I have a brand new turbosmart actuator though..
The tuner did put in new spark plugs on the day of the tune. Also a bit dubious that he rejects my calls when I try to call him...
sorry for the late reply guys. I work crazy hours as a security officer. Will post logs as soon as I can. Appreciate everyone's help.
Edited by Redknight
Idle car. Disconnect coilpacks one at a time. See if when you pull one the car still sounds the same (no noticable change in engine note) and that might be your dead coil
Sent from my SM-G950F using SAU Community mobile app
  • Like 1
Anyone living in surfers paradise that is able to help for $100?
I have taken it to several mechanics and no one knows what the hell is wrong with it!
driving home last night I lost all power, strong fuel smell and the throttle is completely unresponsive. The injectors or engine are ticking really loud, almost like how a tractor idles. And turbo completely laggy.
I took everyone suggestions and disconnected each coil but all I could notice is the engine revs dropped. I am not a mechanic so I have no idea what I am doing. All I know is I spent a huge amount of money to build my car so I can enjoy my pride and joy but its giving me nothing but frustration. I am really starting to hate the damn skylines.
I am desperate for someone to help me out and tell me exactly what the issue is so I can go fix it immediately.
I am more than happy to pay someone just as much as a mechanic if it means diagnosing the issue. Any member from SAU that is living in gold coast?
I am at my wits end.
Edited by Redknight
I fixed my car!!!!
I did a couple of things. My coolant temp sensor was all green and moldy from corrosion. I bought my self some contact cleaner and cleaned it. One of my injector plugs was not all the way in so I secured that. Also one of the wires on the 3 port was loose so I plugged that back in.
My exhaust started to sound beefier, more bass and I could actually hear my turbo spool! My mid range punch was back!
Edited by Redknight
Well...the issue came back. I thought I had fixed it.
No mechanic in gold coast can help me. I have no choice but to sell it and be done with skylines for good. I'm done with them.
Its going on car sales today.
appreciate the help guys.
  • 3 weeks later...
Could be as simple as timing goes off.. Maybe it knocks and the timing gets retarded massively.. causing spooling noises but no performance.. I have seen that too many times than i can count.. take it back to the tuners. Could be a number of things. They'll find the issue
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
