22 minutes ago, ActionDan said:
Thanks,
Yeah bit extreme. People making more power than me wit this pump without doing that.
Yeah, see if a R33/S14 fuel tank hat/lid is the same size. Use that - easier.
The fuel hat off an s14 fits in there but the plugs are different. Not a problem if you swap to s14 plugs and rewire to suit.
You can modify the stock 34 hat in the same way which is what I have done.
If you cut one open you'll see its actually quite restrictive at the part where it bends, well less than a -6 fitting.
I have been running a modified hat from 400awkw onwards. It's pretty easy to drill out the standard fittings and use -6 bulk heads which should be plenty enough for you. -8 shouldn't really be needed in this case.
Cut the webbing out of the way and smooth it out.A dremel is good for this. Just need to get it to the point that the nylon washer is able to seal properly and you won't have any issues.
Some people have gone to the extent of getting a replacement hat made up out of alloy which is the best way of doing it as you can lay it out exactly as you want
Are the RB26 fuel lines 5/16" standard?
I popped that fuel filter in last night and the hoses seemed to go on easy compared to the standard filter Tightened up OK and no leaks while idling, but just surprising.
im interested in milling off the supply hose and fitting a sharp 90 degree bulkhead fitting to minimise losses around that bend, and also be able to upgrade to -6 ot -8 in the future.
I'm using a pwm fuel pump controller so i'm not worried about the return line or jet pump line sizes.
would a -8 90 degree bulkhead fit under the pump cover or would I need to go a -6?
one of these:
or these: (worried about clearance due to radius)
Edited by burn4005
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
