ecr33 narrowband from plx afr for ecu
Hello.
I have an ecr33 skyline (rb30/25det) and going to use Nistune ecu. I have a plx afr gauge (dm-6) and it has a narrowband output so I'm wondering it it'd be worth it to use that signal for ecu? The reason i'm wondering is the plx afm is brand new and the cars o2 sensor is original (now 23 years old). I've heard that people changing o2 sensors get better fuel consumption etc so could the plx result in more accurate readings? I'm having a new downpipe/exhaust made up regardless so that doesnt matter. Dont really want to buy a new o2 sensor for ecu if I can simply use the plx for that aswell.
Thanks for any help!
The whole engine is new (bigger displacement, injectors, turbo, MAF etc) so I'll get it properly tuned anyway. Could the New sensor still be an improvement? Gonna make the exhaust on thursday so it'll be easy to set up.
Microg how did you wire yours? Tried to google for a few hours but couldnt find anything. On my o2 sensor loom (in the engine bay) I have a 3 wire oval connector with blue, Brown and a wire with a white stripe on it.
Yes, I do it all the time for cars I tune as their stock o2 is often cactus and I always recommend they install widebands.
The beauty of simulation is that you can define the voltage output vs the AFR so at times you can be smart about it and move afr range towards the leaner region so you end up cruising at 15.5
Sweet, thanks! So I can simply cut and solder the pin 29s wire to the plx output? Just one wire? And I can leave the two other wires on the o2 plug untouched?
The other 2 wires on the O2 sensor are the ground and the heater.  If you want to save a tiny amount of energy, you could just delete all 3 connections.  Ground not needed with no signal, heater not needed with no usage.
Edited by GTSBoy
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
