R32 GTR Drag Cylinder Head
 Hi all,
New to the forums after a little advice regarding my rb26 head build.
Im currently building a r32 drag car and im looking at building a head that will support 1300awhp+ , before anyone asks the rest of the engine and driveline will be capable of the power im chasing i just want to do the head right the first time around
I will be starting with a new core.
Im thinking about going sum custom cams but unsure who does the best for this sort of an application.
What i would like to know is who in australia does the best porting jobs on the rb26 with proven results.
Also suggestions on the valve train im looking at ferrea 1mm oversized valves but not sure on what are better in the way of spring and retainer kits. Are ferrea, tomei, and supertech all pretty similar in quality and performance?
Are tomei solid lifters and bronze valve guides going to be up there with the best or is there better available?
Also ive heard of +2mm oversized exhaust valves being an option but unsure of who makes them....
Any advice or help pointing me in the right direction would be greatly appreciated.
Thank you
Edited by Dc 32-gtr
Missed word
https://www.sau.com.au/forums/topic/470575-r32-gtr-drag-cylinder-head/
mate,
after getting in touch with the owner of NAPREC and exchanging about 30 emails... .ive just sent a head off to NAPREC in japan which arrived to them the other day. what i'm getting is JAPANESE precision...you cant get that in australia.
the head getting ported & polished to within an inch of its life to bring out the goodness in the +1mm BIG valves.... and the squish is also getting thrown out the door in favour of the legendary hemi chamber
no need for squish when aiming for brute power with no concern for emissions : )
also, you'll want to change the valve seats for 1000ps+
food for thought.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
