i will keep a look out for further updates i am interested in them it sounds like a worthwhile alternative to getting 550cc injectors.I am not after more than 250rwkw and im guessing with an increase in rail pressure they can be pushed closer to 500cc.
Are they a straight swap injector?
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-952620
coming from the sr community, i can tell you there are a quite few people pushing there s15 turbos and injectors to around 200-210rwkw with some extra fuel rail pressure
and there pretty maxed out at around 190rwkw with stock fuel rail pressure..
so if you have 6 of then i would imagine something like 200/4 x6= 300rwkw would be possible with extra fuel rail pressure
there is someone on silviansw.com selling a set of 4 for $300 for anyone interested too :D
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-953643
I am currently converting my rb30 to turbo power and ive read that the vl injectors run out of steam pretty early in the piece. I have also heard that R33 GTR 444cc injectors may well fit straight in. If anybody knows it would be a big help. May as well buy the GTR injectors instead of the Holden variety if they fit.
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-953655
Simple numbers guys, 480 cc's in a 6 cylinder engine = ~480 bhp.
So 480 bhp / 1.34 = 358 kw
Less say ~65 kw for drivetrain losses = 293 rwkw.
That's at standard fuel pressure, whatever that is for an S15. Knowing Nissan, probably ~38 psi above boost.
Hope that helps :)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954758
GTR's are top feed low impendence.
You'd need the resistor pack also and probably a custom/GTR fuel rail (?)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954777
Check out http://www.calaisturbo.com.au/index.php
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-954840
I believe that late ( '96 and later) model 300zx VG30 uses injectors that will fit a RB25.
no responcability accepted for accuracy of information in the previous sentance so don't come running to me when your pistons are a melted pool of slag in your sump... :-)
https://www.sau.com.au/forums/topic/47058-bigger-injectors/#findComment-955846
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
