Oil temp sensor questions RB25/30
Hi All,
Hoping someone knows a bit more about this than me. We are about to fit an oil temp gauge to our track car - now with a 25/30 motor. We have used the RB30 oil pressure gauge sensor hole in the block (1/8 BSP just behind the oil filter) to run a braided line to the VCT feed in the head (via an elbow and some 1/8 & 1/4 BSP & AN fittings), and the easiest place to put the temp sensor is in this line. I am planning to replace a 1/4BSP joiner with a 1/4BSP T-piece (all female threads), and use a reducer to fit the sensor into the side of the T-piece. The T-piece will be at the block end of the line - as the oil exits the block, not as it enters the head.
My question is - how much oil flows through this line feeding the VCT solenoid & into the head? This will determine how much the temperature in this line varies from the oil temp in the engine. I believe that this oil feed also lubes the front cam bushes, so I expect there is continous oil flow through the line - is this correct? Is the oil at this point likely to be the same temperature (or close enough for getting a reasonable indication) as the oil in the engine?
Yeah you really need it in a hole made for it or perhaps an adapter in the hot side of your oil cooler lines (if you have one) so you can put the sensor in the main flow of oil. VCT line will never flow enough in my mind
And a sandwich plate is quite easy to install aswell. When my engine was out I welded a bung to my oil pan for the temp sensor. Used my sandwich plate for vct feed and oil pressure sensor
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
