Originally posted by GTS-t VSPEC
Yes I know a few people who went the same path, and while they are a good clutch I do not think they will hold up under the punishment of 300+rwhp. They are however very easy to drive, but my twin plate only took a couple of days of getting used to. Although second-hand twin-plates are becoming more common they are quickly snapped up, due to most people frying the factory one.
See'ya:burnout:
a bit off the topic..for those second clutch, normally only some % left, can they be re-condition? or rebuilt? Looking for one NISMO and OS clutch..thanks.
  • Replies 97
Yes the name brand clutches can be rebuilt, we have had it done to a number of clutches including OS Giken and Nismo. They come out feeling like brand new, and will often save you a bit of money over buying a new clutch.
See'ya:burnout:
Many of the multi plate clutches can be rebuilt but they are not cheap to get done. Would only be worth buying something cheap.
I thing extreme are starting to make their own twin/tripple plate clutches as well, a lot cheaper than imported stuff.
It is good that some Australian companies are starting to provide performance parts in competition to the Japs, lets hope they make a good tough clutch for the skylines.
See'ya:burnout:
Totally agree, the Japs do what they do well, there is no doubting that, but I do believe that australia can do as well or better, and they regularly do.
...only that it still costs the same price.
In some cases yes, but in others no. I got an aussie made coola, 2PSI drop at 650hp cost $800. Also $400 for a custom built dump and front pipe, hand finished and blemish free (have you ever had a good look inside a HKS one?)
Besides, I know where I would sooner spend my money - in Austalia.
IMHO
Steve,
I totally agree with you, aslong as the product is as good then I want to spend my money in Aus. I think the market here is starting to catch on to the growing demand for performance parts, with many Australian parts now being used overseas aswell.
I don't see the point of spending twice the amount of money on exactly the same product just cause one is a Jap brand, compare them on performance/reliability.
See'ya :burnout:
See'ya:burnout:
I agree completely - which is one reason I chose EMS for my ECU (plus is heaps more flexible than others). Also , I decided today to get a Australian Manufactured 6 puck clutch - should be as good or better than a Nismo or OSG one, and half the cost (installed). Actually when I come to think of it, out of all my mods, I didn't buy one new Jap branded part.
Cat = USA
Dump & Front = Aussie
Turbo = Aussie re-engineered (Org Jap)
Injectors = Aussie re-engineered
ECU = Aussie
Plenum = Aussie Custom
Surge = Aussie Custom
Fuel Pump = Bosche (German right)
Catch Can = Aussie Custom
Clutch = Aussie
brendanf,
Once you have had some time with the clutch then let us know what you think of it. It will be good to have a list of Aussie manufacturers that can compete with the Japs.
I tend to get alot of my stuff custom made here, the workmanship is very good and generally much cheaper.
See'ya:burnout:
  • 4 months later...
Clutch is good - quite happy with it - shudders a bit when you take off up a hill, but I understand this is normal because of the grip of the pucks & kevlar.
Re Mods: I didn't get to try them out to full potential before the motor lost compression in two cylinders. (Don't know why yet cause the head hasn't come off yet) Suffice to say that the compression is so bad (60) that we all know what is the problem -What caused this could be a number of things, as we all know.
Right now the car is in my Garage, waiting for me to save up for a full re-build with forgies, strengthend rods/bolts, o'ringed/dipped block, the best bearings I can get, maybe some head work, maybe a metal (or composite) head gasket and definitely cams - AIM = 300rwkw (reliable, safe, strong, bulletproof kilowatts)
When the engine is out, I'll be getting the injectors tested/flowed cause what happened, shouldn't have (in my opinion) - I was only running 14PSI at time failure.
So ATM I am reading lots and lots about what others have done and are doing in terms of engine rebuilds - Also happy to take suggestions/recomendations from the forum on what I should/shouldn't do to attain my bulletproof 300rwkw. The only other mods I had done since this thread is a 1:1.5 adjustable fuel pressure regulator.
Cheers,
Thanks Tony, Your 100% right - I was devesated when the engine went - esp after spending a lot of time & $$ on it and not actually getting to enjoy it at the track - Plus, so soon after the mods - (I even tried to sell it as is, I was sooo pissed off) But I'm over it now, and am looking on the positive side.
1) Will have more reliable power after the next stage
2) Have plenty of time to research all the right moves
Thanks to everyone for the help so far - there is more to come ...... I even changed my avatar to refelct my new found enthusiasm.... he he :D
    • PULSAR PSR2860R 0.86A/R or 0.64 GEN 2 Turbocharger Both are -50*67mm 8 blade billet compressor wheel Cheers
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe.....EDIT... nope, the Kraken is a cast jobbie, the REv9 uses welded up stainless, plus $8000 AUD before shipping, installation and tuning) Where else in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit that Pulse fitted, and it was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
