Is this engine compression okay ??
Hey guys did a engine compression test on my engine and got the following results.
1# 135psi
2# 140psi
3# 130psi
4# 135psi
5# 135psi
6# 130psi
The car is a 1998 r34 gtt, is this compression okay for the car ??
The only performance work i intend on doing to the car, is a tune with the stock turbo.
Edited by ruinned
https://www.sau.com.au/forums/topic/470628-is-this-engine-compression-okay/
Make sure you get it with the feature pack.
Gives you option of full flex support by feeding the 0-5V into the diagnostic port. Not to mention anti-lag for launch, great for showing who's boss lol.
You can also check the variance between cold engine dry compression and engine warm wet compression values to guage the health of the piston rings and valve train
From another forum;
a dry test is just how the engine runs and it will tell you only the compression. A wet test is done after with oil in the cylinders, in this "SECOND" test if the numbers go up you will know it is the rings and if the numbers stay the same all is well.
IE dry test on cyl 2 was 30 lbs low and wet the reading was back up to par it is the rings. If the "SECOND" test was still at 30 lbs low it would be in the valve train (valve adjustment) or a sticky/leaky valve.
From another forum;
Cheers for the information, i will prob do a wet test this weekend and see if the results are different.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
