Round 4 - Phillip Island July 1st (95dB) - By AROCA *Limited entries*
Last time at PI for 2017 and we are lucky enough that AROCA are holding a 95dB day! (other days are only 75dB)
This event will sell out quickly so get your entry in ASAP.
When:
Saturday July 1st 2017
Where:
Phillip Island Grand Prix Circuit
Back Beach Rd, Phillip Island VIC 3922
https://goo.gl/maps/43e4m1BtEWu
Entry cost
$280 until 25th of June and $320 after that.
Full event details and entry form which need to be filled out and sent back to Neil Choi. His details can be found on the entry form.
AROCA PHILLIP ISLAND SPRINT Supp Regs
AROCA PI ENTRY FORM
  • Like 1
I was in the same boat as you Travis, I called Neil on the form and he told me he has seen my entry but has been busy so hasn't processed it yet.
He assured me i'm entered so i'd guess you're in the same boat.
  • 4 weeks later...
On 2017-7-1 at 2:20 PM, acsplit said:
I saw this on the day... Awesome photography and great quality prints. I was extremely tempted to purchase... But decided against it. Could pay for another event entry!
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
