about a month ago, i did the little bodgy mod ( http://www.skylinesaustralia.com/forums/sh...ead.php?t=42895 ) which basically gives you constant 7-8 pound boost. which i was quite happy with the result.
about a week ago, on my way to work, i noticed i was getting no more than 3 pound boost (wouldnt go over the line between 0 and 7 on the stock boost guage)
once i got to work i popped my bonnet and saw that the red wire (which was inside the black one to be earthed) became loose and wasnt connected to earth.
i went and purchased a boost controller assuming that my boost solenoid had carcked it but that hasnt fixed the problem..
could it be my computer which is restricitng it to 3? i`m really confused!
any suggestions as to why i cant get over 3 pound would be greatly appreciated!!
babs
https://www.sau.com.au/forums/topic/47064-boost-prob/
The stock guage isnt in psi, its in mmhg. +7 is 14psi.
With the earth wire hack (that i wrote up) you should go just on the 3/4 line or like 1 spec above it which is about 7/8psi. If you are in standard mode (no wire hack or below 4500rpm in normal mode) you will be 1/2 between a 1/4 and 3/4 which is about 5psi.
If the wire comes loose and doesnt earth then the solenoid is in a closed state which is 5psi.
The ecu will try and ground itself above 4500rpm but because youve hacked the wire it wont do anything and just keeping plodding along.
Solution?
Fix the loose earth wire or return it back to factory setup. Theres nothing wrong, simply the hacked earth that youve done has come loose and no longer working, ie: the circruit isnt complete anymore and the solenoid is closed (5psi mode)
https://www.sau.com.au/forums/topic/47064-boost-prob/#findComment-952354
ok, thanx for the reply..
but that still does not explain why i cant adjust my boost with my dual stage boost controller? with the switch on or off i still get the same amount of boost (just below the 3/4 line) which u pointed out is infact 7 pound..
also how come once i did the wire hack i was getting aprox 7/8ths (close to the +7 on the guage..) and i understand the concept of earthing the wire, but what is the red internal wire for (wrapped inside the black one)
https://www.sau.com.au/forums/topic/47064-boost-prob/#findComment-952377
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
