Am I the only one still playing Forza Horizon 3?
Steve85
 Share
Still loving this game. Have recently gotten into the "Rivals" section. I'm attempting to be in the top couple of hundred for each track.
Also love taking photos!
Haha... well I like it. Keeps me entertained, I don't spend enough time to warrant a full wheel and PC setup. So this will do in the meantime.
I sunk hundreds and hundred of hours into Gran Turismo 2, 4 and 6. Finished them all, it's where my love of the LM came from.
Holy crap! I had an awesome modifyed mitsubishi fto in granturismo 3. The acceleration was like 0 - 330 in 4 seconds from memory
Yeah that was the FTO LM. I remember it well...
I prefer the Forza Motorsport games more, played Horizon 3 a few times, then got Horizon 2 since I'm still stuck on 360, but got over it pretty quickly, driving at 300+kph through paddocks and fences kinda makes it hard to get into it..
I think the best part I enjoyed of Horizon 3 was driving through my home town, that was pretty cool
I've been playing it on and off mainly when the forzathons are on. I have been playing it with a g920. Bit have gone back to F1 and project cars recently.
Also it is available on PC. Digital and I think maybe it has to be Windows 10
Yeah same. I was going to get the expansions when they were on sale but missed it... Also car packs have never interested me. The hundreds of cars you can get are enough for me... I spend a half hour on the daily forzathon the other and rage quit it though... Who wants to jump a g65...
Ah that bloody G65 jump. Took me forever! Damn game. And yeah I figure I have enough cars without paying real money a second time round. There's enough in the Forzathons to be interesting.
  • 5 weeks later...
If anyone is interested add me as your friend, i don't have a gold membership but like to compare drift and lap times etc in the leaderbaords, my gamer tag is: lmlimitedsteve
(i'm not creative with my names).
 Share
    • Anyone have any tips on replacing the high pressure PS line on a R32 GTR? Mine started leaking and got a new one but can not for the life of me figure out how to get the old one off. I took the sway bar off and disconnected the steering shaft but can not figure out how to get the end that connects to the rack out. I did not want to cut the old one off cause if I can not get the old one off I am sure I will not be able to get the new one on.
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
