NEED HELP RB20DET HIGH RPM MISFIRE
Hey guys i was hoping to get some assistance i own a R32 GTS-T had a blown head gasket at that point could still rev to red line... now i have had the car repaired changed the head gasket water pump timing belt and kit all drive belts had the head machined cleaned and crack tested arp head bolts added brand new iridium spark plugs brand new splitfire coils and a new coil loom etc car is all back together now starts perfect feels fine but when u give it a good rev starts mising at 6000rpm  only things i realy havent changed are igniter afm or exhaust im hoping some of you may be able to assist with some ideas or if you are local to even come out and look over it with me this is my first skyline so i am new to the scene but if what i have stated here isnt enough feel free to ask me direct questions id be happy to brain storm :) thanks guys!
  • Like 1
https://www.sau.com.au/forums/topic/470713-need-help-rb20det-high-rpm-misfire/
  • 4 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
