He's my mate - caught some oil or something on the road while going through the round about and sent him sideways into the pole. Speed etc was not a factor, it was just one of those unfortunate things. Cars prob a write-off and the poor bloke is guttered.
Can't see how that makes him an idiot.
Ouch man, did he have insurance? I know how the oil thing works, I hit some oil on a round-a-bout in Tuggeranong, wasnt speeding or anything, and almost went up the gutter and into the pole because I had no control of the car. To top it off it then spun sideways a bit after it finished understeering/sliding across the oil and I almost wiped out Aurora (he was driving next to me)... but yes to say again, we wernt speeding/racing nothing.
I hope your friend has insurance!!
Yeah, damn oil.
Understandable, poor bloke.
I think what mickGTR was saying was it probably looked like just another fool out in the rain, there were plenty of them over the weekend. Good to hear it wasn't caused by stupidity, but bad that it happened all the same. Hope your friend is alright.
As for what Amaru is talking about, yeah, if he'd gone around i would have worn it, we were just on the way home from...i can't remember, and all of a sudden his car steps out and then snaps back, and i'm just watching on from a metre away in the other lane.
Scary stuff
Its all good - I'm just lookin out for me mate.
He's in pretty good shape actually, not even sore so he's lucky.
He has insurance and they're on the case at the moment. Fingers X'd he'll be in the position to get another 'line. Its just a pitty this one is gone cause it was clean as.
A 5 minute trip from red rooster to erindale shops last week in the rain, 8 separate guys had it out sideways through the round-a-bouts in the area, one nearly clipping me going i nthe other direction.....
But more of a warning to guys down south, over the last few weeks Ive noticed sand covering oil on the roads in some streets n near round-a-bouts. Looks like there may be some wankers putting it on the road for their own personal enjoyment.
Yeah there are. Noticed a few times there's been oil down towards Erindale/Wanniassa/Calwell/Richardson, and the general Tuggeranong area.
It's a serious problem, because one day someone won't see it, come through their patch of oil and kill someone innocent .
Bah
Thats ****ed guys..... oil on the roads...
I saw a similar thing happen to a black skyline late last yr... Was driving me mates R31 and Down from woden past fadden, The big round about there.. Black R32 tried to chase me round the bout, lost control and hit a light pole... Saw the whole thing in me Rear view... Not a pretty site. He drove off, not sre of the damage, but he left me a nice side mirror..
I had to pick up the light pole and move it off the road before anyone hit it..
Was more of an Idiot driving that time.. Trying to boost it around the bout... i dunno... But didnt hold..
I just passed it as it happened, It looked like he just lost control....IDIOT.
Should have known how slippery the roads are.  He had to learn the hard way!
Now that we know that there may be more to the story, how about you retract your comment and in future dont immediately brand someone a tool when you dont know the whole story.
Generalising like that only makes you look like the idiot.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
