Hi i have just removed and i will clean before i sell my r34 Garrett/op6, PU, highflowed turbo with hks actuator, no shaft play, T3 profile, only removed due to rebuild and apgrade engine so wont be using. Has been on car for about 3years but only seen around 10000k, never had any problems, highflowed by tao (hypergear) capable of 450hp only ever boosted to 14psi. $1200ono..20170603_150905.thumb.jpg.c2f9425dd52a0fb2cd1796a1928712a9.jpg20170603_151010_001.thumb.jpg.40e8a80c1a269aa926f2ca48ffe5be0f.jpg
https://www.sau.com.au/forums/topic/470724-sold-r34-pu-op6-highflowed-turbo/
Hi mate, in total as tao did it all it was around 1400 or so.. i cant remember 100% but it was for the highflowed service, housing and actuator. And capable of 450hp comfy but can do 500hp but that was be probably maxing it out.. Cheers
Yeah mate.. inboxed ya.. but if ya didnt get it i did one of those online quotes and it came up at around $30 but if any more id put towards if interested if less im happy to give back.. cheers mate.20170610_165029.jpg
  • Like 1
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
