  • 3 weeks later...
Guest darrinspencer
Here's the one i was after.....
This is a 34 gtt front modified to suit a 33 gts
This one was for sale about 2 months ago on ebay same photo
Was a second quality for about $300
Use that email address in the photo to contact the seller
The guy was in Perth.
Hope this helps
