Hey blokes i have a imported 2001 r34 rb25de neo 130,000kms, i cant part with it and ive come to the decision i want to turbo it instead of buying a gtt. ( i know alot of you will be against that [emoji23])
I got a quote from 999 auto to do the conversion,
I want your opinions on wether that is too much for the neo engine because i was hoping to get it a bit cheaper flog the neo and end up buying a 25/26 or hopefully 26 in the long run and put in it, is the neo going to push much more power after sinking that much into it?
Any advice is greatly apreciated [emoji16]
https://www.sau.com.au/forums/topic/470734-turbo-conversion-for-r34-na/
12k lmao f**k that.
Take a quick look at the RB25DE+T threads here;
That would be an "ok" bunch of parts on a DET engine.. however with a DE+T engine with that setup and you've got a fireball on your hands.
Literally buy stock DET parts from facebook/forum and slap them on. Or sell and buy GTT as suggested :)
  • Like 1
To be honest, the quote he has been given isn't really that bad. The cost would be similar to take a GTT and take it to what is essentially a GTX3071 -320kw style build.
It is a very expensive exercise.
You will almost certainly blow the NA engine at that point too. GTT engine would likely be ok.
Put a V8 into it instead :P
  • Like 1
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
