Nissan Stagea WC34 1997 Series 1 RS4 V Auto
Nissan Stagea, WGNC34 1997 Series 1 RS4 V Auto
Price: $4,200
Located in Anglesea, Vic (on the Great Ocean Road)
140,000 km (imported with just under 80k on the clock)
First Australian owner (11 years I think I've had it now)
Modifications:
  • 18" wheels
  • 3" turbo back exhaust, including stainless split dump and high-flow cat
  • K&N filter in standard airbox
The good:
  • Low kms
  • Neat interior
  • Near new Pirelli tyres (Cinturato P1)
  • Stock engine and gearbox, not boosted or thrashed
The not so good:
  • The car was painted in Japan, poorly. It should be dark green and really needs a respray, if you are fussy at all
  • Body kit was also fitted in Japan and requires attention, fitment, paint and some repair (fibreglass)
  • Rust in the doors under the mirrors, both front doors need replacing. I have sourced one that will be included in the sale (pearl white in colour)
  • Rust in the centre of the tailgate, was behind badge (I have the badge still) needs repairing, tailgate could be repaired or replaced
  • Coil packs need replacing (hot miss at idle)
  • Small exhaust leak somewhere, I haven't tracked it down yet
  • The clear coat on the wheels has passed it's used by date and they all need refinishing
Contact: Luke
Phone: 0414 766 260
Email: luke [at] munchdesign [dot] com
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
