17 hours ago, Spec-s Gttt said:
Call this guys up dude they pretty good tune cars and mods speak to sam
From what you've posted appears to be a graphics mob, a car audio installer and a panelbeater? Where does tuning fit into it?
1 hour ago, AC34GTT said:
Anyone have experience with Race Pace in Bayswater?
Yes, a forum favourite. Did fantastic work installing some tricky mods and tuning my GTS-T with a very safe and "factory" feeling tune - would happily re-use.
I've nothing but good things to say about Racepace. Although, I will admit they aren't the cheapest around, but at least you know it will be done right the first time. (In my experience).
Good to know! Now I've gotta decide between Racepace and Chequered!
On 05/06/2017 at 3:55 PM, AC34GTT said:
I've heard nothing but good things about Chequered Tuning. But they are an hour each way from where I live...
May I ask what work you had done at Chasers? Just tuning?
Car was stock originally - They installed power fc, PFC boost controller, injectors, fuel pump, and high flow, then tune.
  • 4 weeks later...
Finally got my r33 gtst tuned at chequered.
Car made 258rwkw at 17-18 psi peaking to around 20psi in the midrange.
Hks gtrs turbo, blitz return flow cooler, good 3 inch exhaust, 1000cc xpurts and other supporting mods.
Car now makes full boost at 3500rpm in comparison to full boost at 5000rpm it made with the OP6 hypergear highflow at chasers.
  • Like 1
  • 3 weeks later...
On 6/8/2017 at 9:44 PM, vxsr33 said:
Personally I've been to chasers for a tune and i wasn't too happy with the outcome. At the time i had a hypergear g3 r34 highflow turbo on my r33 gtst, blitz return flow cooler, full exhaust and all supporting mods.
I was happy with the power of 250rwkw at 16psi, what i wasn't happy with was the fact the car was making full boost at 5000rpm.
When i saw the dyno sheet i had a chat to paul the tuner about why it was so laggy and he basically just told me it's the turbo and he can't do anything about it.
Even though i had a return flow cooler, exhaust was a bit restrictive (wasn't too bad though) and the bigger turbo i don't think i should have been reaching full boost no where near that late. I wasn't happy to not get any suggestions or solutions other than to get another turbo.
Not trying to bag chasers out or anything just sharing my experience, heaps of other people have been very happy with their service. Other than that the car felt way smoother to drive, idled perfectly, cold start was perfect aswell.
Imo if you have a hypergear turbo go to chequered since they deal with hypergear all the time.
Can't blame the tuner if you bought a shit turbo and have a less than healthy engine.
Much better choice of turbo!
Sounds like the tune was fine on the previous setup but the slightly tired old RB25 is letting you down a bit. As long as it drives good power is irrelevant.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
