Hi guys, been on the forum for quite some time but never really posted as i tend to be a bit more active on and English one... however i found this forum has loads of great technical info.
I finally had a weekend free to put a GTR M.F.D. into my R34 GTT
Overall went fairly well.... wondering if anyone else has done this before as I have 2 issues.
1. the cover that goes over the unit sticks up at the back (near the windscreen) and won't sit flush with the dash. Does it need to be modified to fit or am I missing something.
2. It doesn't seem to be picking up a reading from oil temp or water temp sensors. Anyone have any advice on why or how to fix. The oil temp reading is currently wired into what used to be the triple gauge meter for it and the water temp is wired off the back if the Speedo gauge (as per attached wiring diagram) but no readings from either.
I know a few people on here have done this mod so....
Any suggestions??
  • Like 3
https://www.sau.com.au/forums/topic/470746-gtr-mfd-into-r34-gtt/
Good to see it worked I have also just finished putting one in my gtt and it looks nice..
About the cover not sitting flush with dash I personally think that it is supposed to be like that. If you follow the top side edge line of the cover you will find that it lines up with the dash.
Yes that's pretty much what needs to be done .
I first connected the AMB to the intake sensor and ran the diagnostic mode it shows that it had the sensor registered but wouldn't show in the display. Then I connected the same AMB to exhaust temp and ran the diagnostic mode it registered the exhaust temp as well and then finally both the intake and exhaust temp display was showing. Hope that helps
  • Like 1
I'll give that a go when I get the car back it's getting upgraded and mapped atm
  • Like 1
Cheers for this. Got it all working spot on now!
  • Like 1
  • 2 years later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
